05-11-2024, 04:29 PM | #1 |
Liked 51 Times in 17 Posts
Total seal ap steel ring set- ceramic coated
This new ring set is Manufactured from 440B stainless steel which is stronger, has Longer life, and precise tolerances.
The face and tops & bottoms of the top rings are all coated with a friction-reducing CERAMIC and low-friction matrix of materials to transfer heat and prolong cylinder life. It will not chip, flake or delaminate. It withstands pressures and heat far exceeding any automotive environment. $495.00 Bore Size: 4.035" Top Ring: 1.5mm Second Ring: 1.5mm Oil Ring: 3mm
Billy/Liam Hampton |
