Liked 754 Times in 213 Posts
Do you know the reason why the 4 cylinders Ecotec engine is penalized so much, in minimum weight VS all others 4 cylinders?
AA/AF: Minimum weight: GM Ecotec, 2,050 pounds, all others 1,750 pounds. BB/AF: Minimum weight: GM Ecotec, 2,350 pounds, all others, 2,050 pounds. |
I also see in the turbocharged paragraph that the size is limited at 68 mm for the Ecotec and limited to 74 mm to all others 4 cylinders 4 valves...
This engine get a lot of restrictions for some reasons... |
Liked 566 Times in 135 Posts
Hi Charles, I don't have an "official" answer but remember that those classes grew out of the old NOPI/NHRA Sport Compact racing series.
From what I understand, the Ecotec engine dominated every class and probably helped kill the series. I imagine NHRA made "parity adjustments" to level the Ecotec with other combinations. It would be similar to how a FSS/SM Mustang would need a bigger pulley than a COPO or Drag Pak even though it's running in Comp. |
#4 | |
I didn't have any kind of interest for that serie at that time. Thanks, I appreciate your input. Keep on, Last edited by Charles Stewart; 06-20-2024 at 10:20 AM. |
#5 | |
Thanks again for your support, |
