Liked 20 Times in 9 Posts
can anyone tell me if they have raced or dynoed a cam with these spec.s' and if so can you tell what kind of hp and torque did you get out of the engine and at what rpm,spec's or :@.050 intake 278 duration .465 lobe lift and exhaust @.050 292 duration .440 exhaust lift using a 1.7 intake rocker intake 1.65 exhaust, lobe separation 108
Unfortunately for that type of question, you have to say what kind of engine you have. Further still, why don't you give Jones Cam Designs a call since he has one of the most accurate modelling programs around. Their number is 704-489-2449
#3 | |
307/317 @.020" 278/264 @.050" 201/197 @.200" .684"/.660" 106 degree lobe seperation @ 106icl HXL / RZ lobes 7800rpm shifts 8200rpm past the lights 317/330 @.020" 283/291 @.050" 201/? @.200" .680"/.632" 106 degree lobe seperation @ 106icl Lunati 7800rpm shifts 8400rpm past lights 327 small block with 3.25" stroke so in a large engine im not sure what they would turn How about some more info about your combo? Heads? Bore? Stroke? |
Liked 1,983 Times in 597 Posts
Are trying to use this cam in a small block chevy? It looks like its a stick shift cam.
Mike Pearson 2485 SS |
