Old 01-24-2009, 01:01 AM   #1
Greg Bronn
Default Garage / Shop clean out sale lots of parts
Listed below is an inventory of parts I have for sale, There are lot’s of new in the package parts, and lots of great condition used Part’s, NO JUNK! I am motivated to sell, and if you are interested in anything on the list, let me know, you can also make offers on anything and everything. I will also make discounts on multiple items and package deals. I can provide photos of any of the parts on request. Thanks for looking. Please reply via PM on the site.
(1)- TCI #242200 10” Competition torque converter, just freshened by Transmission Specialists in Dec. 08, new bearings, sealed in box, have receipt to show work. Fits turbo 350/400 transmissions, or Powerglides with a turbo spline input shaft. $400
(2)- ATI Powerglide trans brake valve body, with tail shaft plug connector, internal solenoid, used, but very nice condition $95
(3)- Holley Carburetors: (1) Barry Grant modified #9375, 1050 Dominator, very nice condition, 3 circuit, super smooth progressive linkage. $425
(1) #4779, 4150 double pumper, with dual 50cc acc. Pumps, 1:1 linkage, notched secondary float with jet extensions, milled choke housing, nice carb! $225
(4)- (3) Barry grant 2 port regulators, just rebuilt by Barry Grant. $45 ea
(5)- (4) Holley Blue fuel regulators, used, good condition. $15.ea
(6)- Assorted New in the package carburetor spacers:
(2) TD Products #2109, 1” aluminum Q jet spacer, Summit $25.95 $15.ea
(1) CP Products #40214 2” aluminum 4150 open spacer, Summit $30.95 $20
(2) TD Products #2028, 8 degree, 4 hole wedge spacer, Summit $69.39 $40.ea
(2) TD Products #2445, 1” phenolic, 4150 open spacer, Summit $62.69 $50ea
(2) Moroso #64940, 1: plastic, 4150 open spacer, Summit $31.95 $20ea
(7)- (1) Barry Grant #120004 notched 4150 float, new in the package $10
(8)- Pair of SBC 292 casting #, “turbo” angle plug heads, 2.02 / 1.60 5/16” stem Manley stainless valves .100 long, Fresh valve job and surface completed by Juan Mendoza of Flow Technology Racing, Ported, 210cc intake runners, 64cc chambers, magnafluxed, very nice set of heads. Includes 3 sets of Mr. Gasket #114 intake gaskets, new in the package Also have a Holley 300-25 Strip Dominator intake manifold ported to match these heads, good condition, has been repaired, (welded) but is in perfect working condition. $950
(9)- (1) New set of Comp Cams #946-16 valve springs, Triple spring, 1.645od $250
(1) New ½ set of Comp Cams #996-16 valve springs, Dual springs, 1.625od $125
(1) New ½ set of Manley #22458-16 valve springs, Dual springs, 1.625od,
H-11 tool steel, 270 to 280 lbs @ 2.00 installed height $125.
(1) New ½ set of K-motion #7330 Titanium, 10 degree retainers $75
(1) New ½ set of K motion #7331 10 degree valve locks $25
(10)- 1 Pair of SBC 461 casting heads, 1.94 / 1.50 valves, bare, good condition $200
(11)- (1) ½ set of Crane “gold” aluminum rockers, 1.6 ratio, 7/16” stud, used $50
(12)- Small Block Chevy, and Big Block Ford engine bearings, my coveted stash of Vandervell, small journal, Main and rod sets, new in the box, these are in a Speed Pro box, but they are Vandervell bearings.
Mains:
(3) Sets #360-7001-.010
(4) Sets #360-7001-.020
These are in Vandervell boxes, and are also new in the box
(1) Set of Rod bearings #VPR673 .020
(1) Set of Main bearings #VPM768 .020
These are in Sealed Power boxes, but are Vandervell bearings, and are also
New in the box
(1) set of Mains #MS-429 P-.010
(2) set of Mains #MS-429 P-.020
These are Ford 429/460 bearings, in Sealed power boxes, and are also new in
the box
(1) set of #360-7161- 020 Vandervell Mains
(2) Set of #363-6005-std Uncoated (black) Speed Pro race bearings.
Asking $50.00 each for the Main sets, and $35.00 each for the rod sets, or best offer.
(13)- Small Block Chevy 8” Fisher balancer, fully degreed, rebuildable, nice condition, with extra center hub. Standard SBC crank snout. $175
(14)- Shogun cool tool converter cooler plate, new, Powerglide model. $60
(15)- (1) Barry Grant fuel filter, ½” NPT inlet outlet, including new o-ring kit-
#170036 and “new” filter element #170019. $45
(16)- Moroso #65800 Carb mounted tool tray New condition, not in box. $40
(18)- (2) Pairs of Moroso Rod ends #90360, ¾”X ¾” RH threads, new in the package
2 per package $25ea
(19)- Big Block Chevy, internally balanced, steel balancer, degreed, used. $50
(20)- MSD Ford billet distributor #8580, like new condition. $160
(21)- MSD Blaster coil #8202, new in the box. $30
(24)- Crane Cams cam button/spacer #99164-1 new in the package. $15
(25)- Crane Cams #99164-1 used cam buttons (2) nice condition. $10ea
(28)- (1) Simpson 5 point harness, cam lock, #29114 black in color,-
New in the box, Out of date, needs recertification. $125
(29)- (2) Simpson 5 point harness, cam lock, #29104 black in color, slightly used-
Very nice condition, out of date, both need recertification. $75.ea
(30)- Small Block Chevy roller camshafts, used, nice condition:
General Kinetics C1RA 326/334 duration, 472/425 lift 108 LC $100
Crower Cams solid roller 270/276 duration, 622/622 lift 103LC $125
(31)- (2) upper (2) lower 1st gen Camaro factory A Frames, new/installed Energy-
Suspension urethane bushings (red) #3-3101R, and new upper and lower-
TRW Ball joints, assembled, never mounted after installation. $400
(32)- Felpro, Mr Gasket, GM, and Ford Motorsport gaskets, all new in the-
Package unless noted:
(1) Felpro #1231 intake gasket set $15
(1) Felpro #1230 intake gasket set $15
(1) Felpro #1619 valve cover gasket set $10.
(2) Felpro #1018 head gaskets $28ea
(1) Felpro #0000 exhaust gasket set $15
(1) Felpro #1206 intake gasket set $10
(1) Felpro #1205 intake gasket set $10
(1) Felpro #1244 intake gasket set $10
(2) SCE dead soft copper, .080 thick, head gaskets, only used once $50pr
(1) Ford Motorsport #M6584A460 valve cover gaskets $20pr
(1) Mr Gasket #5812 intake gasket set $15
(1) Mr Gasket #101B intake gasket set $5
(1) Mr Gasket #100 intake gasket set $5
(1) General Motors #8677743 4L80E trans pan gasket $30
(6) Felpro misc #2712 water pump, fuel pump gaskets. $10
(33)- Moroso #71600 Dzus button wrench, new in package $5
(34)- Moroso #63450 1 ½” hose quick disconnects, (2) new in package $10ea
(35)- K&N stub stack, 4150 style, used, good condition. $10
(36)- TRW #CS 8088 coil springs, new in the box, many applications. $40
(37)- Custom seat mounts for a poly propelyne race seat, to mount to the-
stock seat mounting holes in a Camaro / Nova floorpan. Made from-
¾” 4130 steel tubing, nice fit, super strong and light. $60pr
(39)- Wilwood brake pads #150-3668K gator pads, new in the box, these-
Are for Dynalite 4 piston calipers. $25
Greg Bronn is offline   Reply With Quote
Old 02-06-2009, 10:20 PM   #2
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: Garage / Shop clean out sale lots of parts
Do you still have the regulators.....email me at bobmulry@yahoo.com
thanx,
bob
Bob Mulry 7516 STK
A & M Motorsports
Old 02-06-2009, 10:58 PM   #3
b.guggenmos
b.guggenmos's Avatar
Liked 3 Times in 1 Post
I am interested in the distributor. Do you have the springs and bushings for the adavance and do you know how much to ship to 98501. Thank You, Brian
b.guggenmos is offline   Reply With Quote
Old 02-06-2009, 11:17 PM   #4
robgbar
how about a picture of #37, would it be nhra legal? robgbar@verizon.net -thanks rob
robgbar is offline   Reply With Quote
Old 03-02-2009, 01:27 AM   #5
Willpower
I was wondering what that converter was used for last and if you had any Vandervell Std. small journal rod brgs. around. Thanks Will
Willpower is offline   Reply With Quote
Old 03-02-2009, 06:14 PM   #6
Greg Bronn
Willpower, I bought the converter for another project, had it freshned, and changed directions, so it's up for sale. I have the invoice from Transmission Specialties showing work completed in December of 2008. I do not have any more standard small journal bearings, but I do have quite a few sets of .010 and .020 oversize bearings, all of them are Vandervell bearings, and in their original boxes and sealed in plastic. Let me know if you are interested. You can send me a PM Thanks.
Old 03-04-2009, 09:11 PM   #7
Greg Bronn
Smile Re: Garage / Shop clean out sale lots of parts
Sorry to all of you that have asked about items on my list that have been sold already, This is a list of items "SOLD" off of my list: 1050 Dominator SOLD, BG Regulators SOLD, (1) Moroso plastic 1" spacer 4150 open SOLD, BG float SOLD, 1/2 set of Comp springs SOLD, 461 sbc castings SOLD, Ford Clevite bearings SOLD, Kool Tool SOLD, Ford MSD distributor SOLD, MSD Blaster coil SOLD, (2) of the Simpson harnesses SOLD, all of the Ford gaskets SOLD, Moroso Dzus wrench SOLD, Comp Cams rockers SOLD, Thanks to everyone that purchased items so far!
Old 01-24-2010, 08:00 PM   #8
Peck Racing
Gerg, Do you still have the Manley 22458 valve spring half set and if so what is your asking price?
Thanks,
Mike
Peck Racing is offline   Reply With Quote
Old 01-27-2010, 06:47 PM   #9
Greg Bronn
Mike, please check your PMs. Thanks, Greg
Search this Thread:
Advanced Search
