Old 02-20-2009, 08:21 PM   #1
Darrin Christen
Darrin Christen's Avatar
Default SS 3 speed Auto or Stick $$$$$
If starting from scratch on a new Super Stock car what would the cost difference be going 3 speed auto trans or stick shift. I'm looking for total cost comparison, all parts included to run a auto or stick. Thanks
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 02-20-2009, 10:19 PM   #2
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Re: SS 3 speed Auto or Stick $$$$$
When I bought everything to run a stick it was around 5000.00 and that was with a used Jerico, new Ram clutch, Aluminum flywheel, and bellhousing. A new DR4-4 is over 4000.00 by itself. ED
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 02-20-2009, 10:25 PM   #3
Darrin Christen
Thanks for the reply Ed. From what I understand, a new 3 speed auto could be $5-$6k alone. Are the Jerico and G-force that are used in SS clutchless?
Old 02-20-2009, 10:49 PM   #4
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
I am thinking that initial costs would be about equal. The Jerico & the G-Force would both be clutchless. The stick stuff is so good these days that in my opinion the only way to go. You will not regret it.
Allan
55 Chevy is offline   Reply With Quote
Old 02-20-2009, 10:58 PM   #5
Darrin Christen
Are there any disadvantages to a stick combo? How often does the clutch need to be adjusted or serviced? Are there any issues with hot lapping a stick car? Can the clutch be adjusted to change reaction times? Thanks for the replies
Old 02-21-2009, 04:21 AM   #6
Ed Carpenter
Disadvantages if you like driving a stick none. Automatic guys will say parts breakage. If you have a good trans and the clutch is set up right you won't break alot of stuff. I have a Jerico at home in a box in alot of pieces as a reminder of what happens when things are not right. Servicing depends on how much racing you do. Adjustments(base/counterweight) are made for each track and the conditions that are present. Yes you can adjust air gap for reaction times. You won't have to worry about hot lapping at an national event. The ones i've been to you run at 8:00am sit for 6 hours and run again.
Ed Carpenter
Old 02-21-2009, 04:40 AM   #7
Darrin Christen
6 hours between first and second round at NHRA D4 races is common, but in the late rounnds they rush you back to the lanes. How does heat effect the clutch and the performance of the car? Ed will you be running any of the NHRA Div. 4 races this year?
Old 02-21-2009, 08:16 AM   #8
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
the cost is about the same for both, but with the clutch technology today there is a lot more adjustabuilty that you can do with the clutch and breakeage is down to a min,there was a guy who raceed in pro eliminator who ran a liberty trans and he was silly consistant with this and finished second in points in 2007,automatics on the other hand can get very costly due to the numbers of converters that have to be tried to to get the best performance gmonde
Old 02-21-2009, 11:06 AM   #9
james schaechter
Thumbs up Re: SS 3 speed Auto or Stick $$$$$
The cost is about the same, but make sure you do some research on the correct transmission and clutch for your application. The Gforce and Jerico that you need has to be "clutch assisted". The sliders are different. One is legal, one is not. Also, there have been improvements in the designs of both transmission types so make sure you get the right version if you are buying used. If you are a newby, don't experiment. Buy a new jerico with a long vertigate and get an advance clutch from youngblood or at leaast a mcleod softloc. It will save you some pain. The autos have gotten way expensive and most do a lot of convertor testing and purchasing. the problem with some racers perception on the stick shifts is that it is hard to drive and breakage problems. That is not the case with the stuff that is out there now. You still need to scrutinize the drivetrain, but with a transbrake,you would have to do that anyway. I can tell you that it is a heck of a lot more fun than an automatic and going laps is not a big deal.
James Schaechter 3163 STK
Old 02-21-2009, 01:16 PM   #10
55 Chevy
55 Chevy's Avatar
Darrin
I made an error in an earlier post. The transmission must be clutch assisted to run in stock or super stock.
Sorry for the misinformation.
Allan
