Old 02-20-2009, 08:29 PM   #1
njk53
Default Weight Placement
If you have to add weight to a race car, where is the best place to mount it. I get conflicting opinions. I have heard over the axle is the best place, I've heard that closest to the rear bumper, and I heard another opinion to put it on the right side over the axle. Which is the right way to do it?
Also is there any publications that deal with stock/super stock chassis set up? Thanks.
Nelson Kowal
Stock 345
Old 02-20-2009, 10:21 PM   #2
Joe DeMarzo
Liked 121 Times in 11 Posts
Default Re: Weight Placement
Coil or leaf spring???
Joe DeMarzo 1317 STK
Old 02-21-2009, 11:52 AM   #3
njk53
Car is a 71 Chevelle Wagon with coil springs.
Nelson Kowal
Stock 345
Old 02-21-2009, 02:00 PM   #4
Philip Saran
Liked 14 Times in 11 Posts
For a stocker you can mount a weight box (max 100 lbs loaded)
over the right rear corner, must be bolted to frame with 1/2" bolts.
Any other added weight must be bolted or welded in place.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 02-21-2009, 02:37 PM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
The right rear corner is always the best place to start with permanent weight...... ..I always put the removable weight closest to the rear axle in the middle of the trunk, and use it only to correct for the scales . .....This way it does not significantly upset the corner weights or the chassis reaction ....Permantly mounted weight can have a significant effect on the chassis reaction and vehicle reaction times . .....Too far back and too high on an otherwise good hooking car ,can really pick up the reaction times and turn a good car into a pain in the butt to find a spot on the tree. ...[see my avatar!]
........Tom
Old 02-21-2009, 08:04 PM   #6
mannymen
Liked 13 Times in 7 Posts
Call Gary Wisecarver or Mike P MPR for the correct weight placement. Besides the right rear and above the axle try the passenger location (underneath the car) and in front of the right rear tire if you can.
N/A
mannymen is offline   Reply With Quote
Old 02-21-2009, 09:28 PM   #7
Joe DeMarzo
I agree with Tom, well said. Leaf springs seperate the rear to push down on the rear hosuing and coil springs squat to push down of the rear. Over the rear housing for leaf sping and in front of the coil spring to benefit from the weight pushing down on the coil springs.
