Old 02-26-2009, 11:20 AM   #11
Kirk Morgan
Liked 81 Times in 45 Posts
Default Re: attn Jeff Teuton Towing "Again"
Hey Charlie give me a call at lunch time, iam a DOT inspecter. 210-887-3331
Kirk, AKA , Mutt
Kirk Morgan is offline   Reply With Quote
Old 02-26-2009, 12:56 PM   #12
Johnny Rod
Arrow Re: attn Jeff Teuton Towing "Again"
Hope this helps. If you have a truck and trailer with a GCVWR under 25999 you do not need a CDL A license. If you are 26000 and over you will need a CDL A license and a DOT medical examiner certificate
(49CFR391.41-39.49). You will also be required to have a IFTA fuel tax sticker registed in your base state and fill out a log book. A DOT# is also required on all truck and trailers with GCVWR OF 10001lbs weather your for hire or not. You can look this up www.fmcsa.dot.gov or (518) 458-9696.
Johnny Rod is offline   Reply With Quote
Old 02-26-2009, 01:30 PM   #13
Adger Smith
Liked 880 Times in 311 Posts
Do things change when you pull with a motorhome?
Adger Smith (Former SS)
Old 02-26-2009, 01:54 PM   #14
Lou SG2340
Motor Homes are DOT exempt. I am 62,000 lbs do not stop at scales & do not have a Class A CDL. Not required in Va.
Some states like Penn. require a motor home license but that varies state to state
Lou SG2340 is offline   Reply With Quote
Old 02-26-2009, 02:12 PM   #15
Johnny Rod
Talking Re: attn Jeff Teuton Towing "Again"
Adger Lou is correct, states vary when length & weight are a factor. They have motor home endorsments in New york and you don't need a DOT# & fuel tax sticker. Go figure LOL. Contact you local dmv for info. John
Old 02-26-2009, 02:33 PM   #16
1chassishop
Any questions about Trk & Trl length and laws.....call Larry Allen! I hear is an expert!
1chassishop is offline   Reply With Quote
Old 02-26-2009, 02:51 PM   #17
jmantle
Liked 172 Times in 81 Posts
It sure would be nice if there was a standardized set of rules that covered all of North America. On a related subject, would my truck and camper be considered a RV or a truck and what speed limit applies to RV's in the states with a different speed limit for trucks?
Jim Mantle
jmantle is offline   Reply With Quote
Old 02-26-2009, 07:30 PM   #18
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Just curious,Anybody have a ballpark weight for a Dodge 4500 dually with a 42'LQ 5th wheel setup,one car about 3000K tools,spare motor about 400lbs,trans etc?Curious if it would require a Class A lic.
Ed F.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 02-26-2009, 09:33 PM   #19
Jeff Teuton
Liked 325 Times in 50 Posts
DOT starts @ 10,000 lbs. One way that will probably get you out of a jam is to have at least enough tag to cover the weight of your truck and trailer. CDL starts @ 26k. Your combined GVW of your truck and trailer if over 26k makes you need the cdl. I sell a few trailers and the manufacturer can rate them less than the weight capacity of the axles. GVW is determined by axle capacity and frame. All truck manufactureres make a truck @ 25999 GVW. Quite legal. Maybe I could upgrade my paper I did for National Dragster and get them to print it again. This seems to come and go. Florida needs an overlength over 65 ft. Can get it on the net with a credit card. Cheap. You can't be a "little bit" under DOT. You really need it all. But they don't usually bother with us, thank goodness.
Jeff Teuton 4022 STK
Old 02-26-2009, 09:59 PM   #20
Ed Fernandez
So if the combined weight rating is over 26K a cdl1 is required?
Ed F.
Former NHRA #1945
Former IHRA #1945
T/SA
