Old 03-01-2009, 06:18 PM   #11
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: subframe connectors and stock class Q
Originally Posted by tomslik View Post
as some of you know, i'm looking at building a 67 american for stock and as there isn't any (to my knowlege) "bolt in" connectors made.
are weld in's acceptable?
what's legal, what ain't?
2X3X.083 " will be adaquate. ....The 01 body makes it easy since it's nearly a straight run to the rear rails. ....Only a short area of the floor needs to be sliced. ...You must weld the floor to the rail.......You can parallel the rear rail and just put an access hole thru it for the spring bolt. Tom
Old 03-01-2009, 06:34 PM   #12
Robert Swartz
Robert Swartz's Avatar
Originally Posted by Dwight Southerland
Sub frame connectors are only legal when used with a roll bar or cage.
??? That's news to me.
Thank you Mark.
I went back to the rulebook and couldn't find this. N/S and above are not required to have a bar or cage. With this implication, you couldn't tie the subframes of an N and up car. Does your V/SA Mustang have the frames tied? From the pictures, you don't have a bar in it.
Robert Swartz
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 03-01-2009, 06:41 PM   #13
Thank you Mark.
Robert Swartz
Yes, and so did the N/SA Omega before it. Teched in by Travis at Indy in '04
Old 03-02-2009, 07:23 AM   #14
Billy Nees
Dwight, I can't find any place in the 2008 or 2009 rule book that says you can't have frame connectors without having a rollbar. Billy
Billy Nees 1188 STK, SS
Old 03-02-2009, 11:26 PM   #15
ron bretemps
Tom, I'd bet there are less than 5 people on here that know what an 01 body is..... LOL.
Is that 67 a 232 2V ?
AMXRON
none
ron bretemps is offline   Reply With Quote
Old 03-03-2009, 04:11 AM   #16
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
AMXRON
yep, with a 3 speed.
what's an 01 body?seriously..
this is a 440 2dr ht (not a rogue)
Old 03-03-2009, 10:24 AM   #17
You might want to re-think that idea.
Old 03-03-2009, 11:45 AM   #18
Tom keedle
Tom keedle's Avatar
whyzat?
Old 03-03-2009, 12:53 PM   #19
whyzat?
Can you tell me anything good about that combination? I'm not seeing it.
Old 03-03-2009, 01:10 PM   #20
Tom keedle
Tom keedle's Avatar
it'll give some seat time until i can get a 290/4speed combo put together?
and it's already in the car...
