Old 03-08-2009, 01:44 AM   #1
Notch1320
Default 12V Battery Reccomendations
My Optima Red top died today.
I was wondering if anyone uses these light weight batteries such as Braille. They offer them in in 6 & 11 lbs and on up from there. I am trying to drop some of the 33 lbs that my Red Top weighs.
Looking for feedback...
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 03-08-2009, 07:49 AM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: 12V Battery Reccomendations
Shawn,
I ran one for a short while. It requires constant charging and will get you in trouble in the late rounds. After the second race where we had to have a jumper battery and cables in the lanes, I when back to a conventional battery.
Larry Woodfin 471W
Old 03-08-2009, 08:13 AM   #3
340Cuda
Liked 805 Times in 341 Posts
The Optimas seemed to have some quality control issues for a while but seem to be past them.
If it was mine I would just get another Optima.
Good Luck,
Bill
Old 03-08-2009, 08:33 AM   #4
Shawn Blair
Shawn Blair's Avatar
Talking Re: 12V Battery Reccomendations
I have two Optima red tops in my car that are 8 years old and they still work great! No alt. charge between rounds when there's time. Also if you have a Optima that has went dead on you and you can't get it to take a good charge, take a standard wet cell battery and run jumper cables from it to the Optima and hook the charger to the wet cell battery. So basically your just charging through the first battery to the Optima. I've seen this bring back a few so don't get rid of it until you try this first,you may be surprised! Shawn
Shawn Blair 6383 SS 634 STK
Shawn Blair is offline   Reply With Quote
Old 03-08-2009, 08:53 AM   #5
james schaechter
Liked 1,442 Times in 302 Posts
I have had good luck with a "Rock" battery. They are 24 lbs but they run my fan and start the car with no problems. They are pricey, but so far a good deal. I bought mine from the CarShopinc. On my 4th season with it. I have an 11lb Carbon Braille. It is good for a few runs if topped off, but bare bones use. They do make larger Braille batteries so that might be fine too.
James Schaechter 3163 STK
Old 03-08-2009, 12:59 PM   #6
SGSST109E
Liked 126 Times in 61 Posts
Optima reds are great. The yellow is ideal for a race car.
SGSST109E is offline   Reply With Quote
Old 03-08-2009, 01:24 PM   #7
Notch1320
I think I will probably go with another Red top. My battery mount cables are set up for it, and it will also accept my spare Yellow Top from the trailer winch in a bind. The mount required a little modification to work with the Yellow because of the slight difference in the battery top, and side post location. My Red Top is over 8 years old, and has served me well. Most of all, the Optima batteries are readily available at most parts stores, in case I need one while out on the road. I still have a long way to go before I need to be worried about a few pounds on the nose. Thanks for the input!!!
Shawn Allsup
K/S 718
Old 03-08-2009, 01:53 PM   #8
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Shawn's right on the charging across another battery. ..I was told to do this by our Interstate battery rep. .....I tried it on a red top that had repeated gone quickly dead. .....It took about two days of charging an a very low rate,but the battery came back and I've been using it for 2 years in a street car that sometimes gos for months without starting. ...Works every time........Tom
Old 03-08-2009, 02:31 PM   #9
Notch1320
I will try it... thanks.
Shawn Allsup
K/S 718
Old 03-08-2009, 04:26 PM   #10
Ken Haase
Hoping I don't need that info and had not heard of it before...but thanks for the tip. Now if I can just recall it when I do need it!
Ken Haase is offline   Reply With Quote
