Old 03-11-2009, 08:13 PM   #1
Dave Toce
Default Playback tach magnet question
I have a 2 channel Autometer playback tach that I use to record every pass I make to make sure the clutch tuning is in line. I just changed a rear gear and when running in the new gear this past weekend I had the magnets come off in the driveway. It appears that the JB weld de-bonded from the U-joint cap. Is there a better or an improved method to attach the two magnets to the driveshaft U-joint caps besides the JB weld that Autometer suggests?
Thanks
Dave
Oopps I just realized I put this in the wrong section sorry..
Dave Toce is offline   Reply With Quote
Old 03-11-2009, 09:08 PM   #2
Liked 10,926 Times in 2,257 Posts
Default Re: Playback tach magnet question
Mark Williams is the answer.
Old 03-11-2009, 09:11 PM   #3
Dave Toce
10/4, I just got a call saying the same. Thanks
Dave
Old 03-11-2009, 09:23 PM   #4
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Collar from Williams
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 03-12-2009, 01:49 PM   #5
west coast
Liked 230 Times in 75 Posts
Autometer also has collars a couple differant rear end sizes and a universal one you can machine.
west coast is offline   Reply With Quote
Old 03-12-2009, 07:30 PM   #6
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi,
Sometimes there are clearance issues with the collar around the companion flange.
As an alternative solution, you can drill the companion flange and insert the magnets with a little epoxy.
Worked for us,
Bob
Bob Mulry 7516 STK
A & M Motorsports
