Old 03-28-2009, 09:26 AM   #21
RockyJ
Default Re: cam degreeing help
Terry i have heard of the stock type balancer ,where the outer ring is slipping
inrelation to the inner ring, so no matter what you do , when the engine is turned over
the TDC mark can slip or move a few degrees. Never saw it personally but have
heard of it.
RockyJ is offline   Reply With Quote
Old 03-28-2009, 10:06 AM   #22
FED 387
Liked 333 Times in 180 Posts
Question Re: cam degreeing help
Stop and think about what you have done so far----try a new lifter, possibly a different balancer ,also use a different dial indicator see what happens---- I know that this next idea will not give you a correct number but pick a different cylinder to try degreeing see if the same error occurs, if it does not ,then something is wrong with the valve train on number 1 cylinder otherwise you might have a bad dial indicator or degree wheel or pointer, timing chain set up or whatever---at least you might eliminate/ isolate some of the possible variables---- Comp 387
Old 03-28-2009, 10:42 AM   #23
Shawn Blair
Shawn Blair's Avatar
Talking Re: cam degreeing help
Have you tried a different timing set? Leave degree wheel where its at and try #6 cylinder and see what you get! I don't know about you but this would drive me crazy good luck.........Shawn
Shawn Blair 6383 SS 634 STK
Shawn Blair is offline   Reply With Quote
Old 03-28-2009, 02:22 PM   #24
buzzinhalfdozen
Liked 11 Times in 8 Posts
Terry,at what reading from max lobe lift are you taking your readings? I have never heard of moving gear 1 entire tooth and not seeing a different reading,perhaps your not coming far enough back from the "nose" of the lobe to get a real number, just a thought. Joe
Joe Buchanan SS/BX 3117
Old 03-28-2009, 03:04 PM   #25
Jim B
Terry, I've seen guys "degree" cams incorrectly by using the degree wheel and math incorrectly that winds up measuring the lobe center of the camshaft rather than the relative position of the cam lobe to the crankshaft. No matter how advanced or retarded the cam is installed the cam lobe center does not change. When you degree the cam in degree BOTH intake and exhaust and mark the degree wheel with whiteout and you'll easily see the BTDC and the ATDC positions and I'll think you'll see what I mean. Good Luck...
Jim B is offline   Reply With Quote
Old 03-28-2009, 05:04 PM   #26
Dragsinger
Liked 99 Times in 60 Posts
for what it is worth, I find it much easier to check intake centerline off a valve spring retainer. Since nothing so far has worked, consider mocking up a head with a checking spring on #1 intake valve. Install the pushrod, intake rocker, set approximate lash, and indicate off the retainer.
Let us know what happens.
Larry Woodfin 471W
Old 03-28-2009, 08:30 PM   #27
njk53
Because you are using the lip of the lifter, make absolutely sure the dial indicator is not walking around the radius of the lifter. Look very closely. I would try taking the point off of the dial indicator and try using the flat. This will give you more surface area for the lifter to ride on.
Nelson Kowal
Stock 345
Old 03-28-2009, 11:22 PM   #28
Terry Waldron
Unhappy Re: cam degreeing help
Timing chain setup is new, tried different lifters,got a new and bigger degree wheel, will try the different dial ind.changes and the degree wheel, see what happens , will let you know.
Terry Waldron 5619 K/S
Terry Waldron is offline   Reply With Quote
Old 03-29-2009, 11:09 AM   #29
STK1217
STK1217's Avatar
Liked 10 Times in 7 Posts
Terry Jim B has something there. If you don't find it PM. me i can help.
STK1217 is offline   Reply With Quote
Old 03-30-2009, 11:42 AM   #30
Phillip marvetz
Phillip marvetz's Avatar
I had a problem with a timing chain on a friend's 360 last summer.We kept getting a reading of 130 for a centerline, tried another chain and got 106.
