Old 03-29-2009, 09:10 PM   #1
Swandog
Question oil pan rule question
I'm slowly putting together my first stocker (N/SA 5.0 mustang). I have a question about the rules regarding oil pans. As stated, you can use a windage tray or scraper combo with an OEM or NHRA approved replacement. However, does the "modifications of any kind prohibited" statement include placing baffles, trap doors, or adding capacity to a stock oem pan?
Swandog is offline   Reply With Quote
Old 03-29-2009, 10:35 PM   #2
Jim Cimarolli
Liked 166 Times in 46 Posts
Cool Re: oil pan rule question
You can do anything inside an OEM pan that you want, but your "adding capacity" will get your butt into a sling.
Jim Cimarolli is offline   Reply With Quote
Old 03-30-2009, 09:01 AM   #3
Liked 10,965 Times in 2,260 Posts
Default Re: oil pan rule question
Jim you forgot to say "unless its a FE ford"
Old 03-30-2009, 11:01 AM   #4
Swandog
Thanks for the reply. One last small question - I assume massaging the pan with a couple of small dents for tray clearance is okay?
Old 03-30-2009, 06:18 PM   #5
Jim Cimarolli
Wink Re: oil pan rule question
Yup, just tell 'em that you banged it on a wheelie, or the return road was rough!
Larry, shame on you for suggesting such a thing!
Old 03-30-2009, 07:00 PM   #6
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Look at an MPG windage tray/scraper and you won't need to dent your oil pan. www.mpgheads.com
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 03-31-2009, 04:39 AM   #7
RJ
How about pan spacers?
RJ is offline   Reply With Quote
Old 03-31-2009, 01:06 PM   #8
Jeff Lee
Jeff Lee's Avatar
I called Steff's a few years ago. They couldn't help but brag about their "deep sump" option for stock class andf how everybody had this option (welded, smoothed with bondo, painted). They even started naming names! And one of them was a competitor of mine. Or at least one of them...
Jeff Lee 7494 D/S '70 AMX
Old 03-31-2009, 02:11 PM   #9
Bill Edgeworth
The added capacity issue is no longer an issue. Stock is now allowed to run accumulators. Throw 5-6 quarts in a 4 quart pan with a 3 quart accumulator and you will have 2-3 in the pan once the accumulator is full.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 04-01-2009, 08:37 PM   #10
JHeath
JHeath's Avatar
Canton makes a stock eliminator oil pan, part# 13-600 . I think several 5.0 stocker racer's use these.
Jerry Heath
I/S '93 Cobra
