Old 03-30-2009, 01:05 PM   #11
Jeff Lee
Jeff Lee's Avatar
Default Re: Overweight Stockers
NHRA has a system for adjusting HP called the AHFS. The system is more difficult to apply due to sandbagging which can sometimes be attributed to running excess weight. Therefore, NHRA SHOULD mandate weight as defined within the parameters of the weight break, i.e., 9.00-9.49 equals C/S-A or SS/G-A, no more, no less.
I'd be willing to bet most, if not all vehicles with drivers can be run within those parameters given NHRA allows movement up or down a class.
I would encourage NHRA to enforce such a rule. It would help the AHFS work as designed.
Jeff Lee 7494 D/S '70 AMX
Old 03-30-2009, 01:35 PM   #12
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: Overweight Stockers
I think what they are trying to do is make sure we don't have more than 100 lbs. of "removable" weight.
Jim Cimarolli is offline   Reply With Quote
Old 03-30-2009, 01:46 PM   #13
Billy Nees
Rocky J, I used to know a Rocky J in Jersey, you wouldn't be him would you? In answer to your question, because the Caddy is a V/8 car and can't fit a lower class then U/SA becomes it's natural class so it would be a natural U/SA no matter what it weighs above 21.99. BUT in order for it to run T/SA it should have to break above 19.99.
Billy Nees 1188 STK, SS
Old 03-30-2009, 01:52 PM   #14
Billy Nees
Charlie, actually there is such a rule and whoever told you that is mistaken. It's right in their black and white rulebook under "Class Weight Breaks". Either they need to enforce their rules or reword the rulebook.
Old 03-30-2009, 03:44 PM   #15
Jared Jordan
Liked 547 Times in 121 Posts
Send a message via AIM to Jared Jordan
I agree. There's nothing in the rulebook, express or implied, which indicates that NHRA has a rule requiring racers to run within the 1/2 lb weight break range required for the class. The only wording in the rulebook re: maximum weight is that you can't have more than 100 lbs of "removable" ballast. So my guess is that the only way NHRA can really do anything about excess weight in a class car is if the racer shows up more than 100 lbs. different from one run to another. The theory being that you can't change more than 100 lbs if you only have 100 lbs. of "removable" ballast.
That being said, I'd hope that NHRA notices the trend of racers running significantly heavier than their minimum and doesn't allow it to become policy (if it's not too late already...). If NHRA wants to enforce this "rule" then they need to supplement the rulebook with some sort of unambiguous language.
Jared Jordan
9 B/SA
2024 Jeg's D7 All Star - Stock
Jared Jordan is offline   Reply With Quote
Old 03-30-2009, 04:55 PM   #16
herbjr
Liked 83 Times in 32 Posts
Its very clear in the rule book
a/sa 8.00 to 8.49
b/sa 8.50 to 8.99.
That tells you exactaly where you need to be. Whats the confusion.
herbjr is offline   Reply With Quote
Old 03-30-2009, 05:37 PM   #17
Angela Macy
Originally Posted by Brandon Peterson View Post
i weigh the better part of 320 ....
Are you serious? You're a big boy (tall wise) but you don't look that BIG. You carry it well!!
Angela Macy is offline   Reply With Quote
Old 03-30-2009, 05:43 PM   #18
herbjr
Guess that Explaines why Brandon Runs M/CM. Cant get any heavier.
Old 03-30-2009, 05:50 PM   #19
Billy Nees
Actually Jared, it is expressed in black print on a white page under"Class Weight Breaks". By implying that there is a minimum weight I would guess that that is an implication of there being a maximum weight.
Old 03-30-2009, 06:14 PM   #20
Jim Cimarolli
I have seen this rule enforced at a D-4 race. If a racer books a qualifying pass at more than 100 lbs. over the minimum, he cannot remove more than 100 lbs. less than that number regardless of his minimum weight.
