#51 | |
I'm definitely not a member of the AHFS fan club. Happy trails, Chuck |
#52 | |
Liked 100 Times in 45 Posts
Ed F. Sorry Chuck,you posted as I was still pecking my post.
Former NHRA #1945 Former IHRA #1945 T/SA Last edited by Ed Fernandez; 03-31-2009 at 02:01 PM. |
#53 | |
Bob Shaws car would need to be considered a special case due to the fact it can't run as a V car. In a way I dont envy NHRA tech,reading all the agendas coming out in all these discussions.It's a matter of the "What's best for ME" and screw everybody else that appears. Ed F.
Former NHRA #1945 Former IHRA #1945 T/SA |
#54 | |
Lee N,It matters when you're hiding an incorrect HP factor. Ed F.
#55 |
Liked 1,829 Times in 427 Posts
It seems like the people piling on this thread do not seem to have the problem of an overwieght stocker BECAUSE,,,, THEY CAN"T GO FAST ENOUGH TO GET H.P.
I will use myself as an example. Bought my car 5 yrs ago It WAS A TURD..Slow IN THE WAY . Got my *** kicked by Tex Miller .Was not fun.Guess what.I have worked hard . Spent the Money and then some..Now I am capable of going pretty fast..So now its a problem because I may run too heavy..You guys should worry about yourself instead of picking on people who work hard to go fast with no reward but H.P. and Weight..The problem with the Orlando deal was it was selective and not right ..You can;t change the rules as you go along..You have to treat everyone the same ..Califonia said the Tech guy was wrong Its not in the rule book..But as good racers the guys complied.. That just Sucks Lets stick with rules in THE BOOK WE ENOUGH ON OUR HANDS You slow guys should by some Nitrois Tech Ain't Check ANYWAY. My 2 cents
james perrone 1290 STK |
#56 | |
#57 |
Liked 7,789 Times in 1,744 Posts
James, you're a smart enough guy to know how to slow your car down without using weight! The pure fact is that the weight rule is written in the book and nobody can read it. A/S is 8.00lbs. to 8.49lbs.ETC. I want to be there when the first racer shows up at the scales with a rulebook and his lawyer and says that he can weigh less than the minimum weight because the weight breaks are only guidelines and if the maximum weight doesn't matter then neither does the minimum!
#58 |
Why not just back up the timing, it's easier on parts than adding a couple hundred extra lbs. Cheaper too.
Ed Wright 4156 SS/JA |
#59 |
I have been trying to get a grip on this issue myself so that I understand it and don't have a problem with weight for my combo in stock....my weight factor is 12.24 which puts me in I/SA.....12.00-12.49 weight break.....I have a classification guide from NHRA that says to take my hp factor times the 12.00 and then add 170 lbs. for the driver for my "minimum" class weight....by doing the same for the 12.49 +170 lbs. for my "maximum"....I can fax a copy of this if someone wants one, I printed it out last Jan.....because the rule book to me is a little vague....like you guys are saying about heavy for the class, I don't think all techs operate from the same page, because I have talked to Glendora and they had to check with the divisions to find out what they have doing on certain issues I have asked about.....
#60 | |
Danny Waters, Sr / 73 Duster "340" |
