Old 04-07-2009, 11:21 AM   #11
RJ Sledge
Liked 291 Times in 92 Posts
Default Re: Blown, injected, 4-valve CJ's at Ennis...
Bill, they originally had Schneider C-4's in them, Rusty Hall had a problem @ Arizona Nationals. They now have JPT (Jim Pacquet) C-4's in them and are performing a lot better, i.e. 9.79 @ 140.17 at Dallas. They did break a imput shaft and I checked out the C-4 and loaned them another one (imput shaft). They are so quite you would think they had mufflers, but they don't. And they do get down the track very quickly.
R J Sledge
RJ Sledge is offline   Reply With Quote
Old 04-07-2009, 11:22 AM   #12
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
I am sorry but I dont think I would want to lock the brakes at 140 120s is hard enough in a Stocker, I really dont envy them.
Bob Pagano A/SA
Old 04-07-2009, 12:19 PM   #13
bill dedman
Liked 6 Times in 4 Posts
Thanks for the info, RJ. I wasn't aware of the change in tranny guys. Sorry for the mis-information; Len's stuff is usually top-flight.
I guess when you start putting 700+ horsepower through a transmission designed for a Pinto, (LOL!) you can expect that it might have longivity problems....
Bill
bill dedman is offline   Reply With Quote
Old 04-07-2009, 12:23 PM   #14
Bruce Noland
Liked 444 Times in 145 Posts
Bob,
Can you womp, womp, womp an injected supercharged car?
140 mph from the off-the-shelf CJs. The tricked out, down to weight CJs will be running 145 mph.
Bruce Noland 1788 STK
Old 04-07-2009, 01:00 PM   #15
Jeff Lee
Jeff Lee's Avatar
What was my prediction? 9.45 @ 143 by the end of the season? Bruce, I couldn't find the post. Can you?
143 should be a 9.29 so I'm allowing for some inefficency.
Mainly because they can afford to be sloppy.
The Challengers will push the CJ's to let it all hang out.
Jeff Lee 7494 D/S '70 AMX
Old 04-07-2009, 01:46 PM   #16
Bruce Noland
Jeff,
I made a similar prediction during the Factory Experimental thread. And I remember your prediction as well. Do you remember which thread it was in? That would help. I think you can go into your own account information and retreive that post/information.
Old 04-07-2009, 02:02 PM   #17
Bob Pagano
Bob Pagano's Avatar
Bruce, I stopped my project over a year ago, it may never be finished. I guessed it was going to be a joke with the CJs coming, now even the Mopar looks like another joke.
Bob Pagano A/SA
Old 04-07-2009, 02:18 PM   #18
Superfan1
Superfan1's Avatar
Liked 2,638 Times in 440 Posts
Talking Re: Blown, injected, 4-valve CJ's at Ennis...
Bill, when you started this thread , you stated that you used a weight of 3358 lbs. for your HP calculations. In another thread on this forum, titled "More enhancement", someone, who claimed to have been there when the car in question driven by Jimmy Holzman went across the scales, states that the weight was 3485 lbs. Try plugging that into your calculator; 127 additional lbs. should make a significant difference.
Bill Seabrooks - superfan1
Bridgeport, Ct.
Old 04-07-2009, 02:37 PM   #19
rtaylor3410
Liked 3 Times in 1 Post
Gentleman, I think NHRA will change Stock Eliminator to 1970 and newer vehicles before they move these Mustangs out of Stock!
rtaylor3410 is offline   Reply With Quote
Old 04-07-2009, 02:50 PM   #20
John Kelley
Question Re: Blown, injected, 4-valve CJ's at Ennis...
I used an online calculator to run the numbers....
Weight 3485#
ET------- 9.79
MPH---- 140
It came out ....Rear Wheel HP....660.67
..........................Flywheel HP....734.08
The online calculator I used was http://www.wallaceracing.com/Calculators.htm
John Kelley is offline   Reply With Quote
