looking at the stock car classifications guide with a 350/250hp motor the power to weight is 13.59 so would this put this car in L/SA am i right
and what would be the idex is it 13.59 or would it be 13.00 |
#2 | |
Jim |
Liked 6 Times in 4 Posts
L/SA is 13.5 to 14.00 lbs./hp, so yes, this car's natural class is L/SA
The L/SA index is 13.00-sec. for the quarter-mile and 8.26-sec. for the eighth. Hope this helps... Bill
Bill |
so when your deciding what engine package you want to run it doesn't have to be out of a 1970 nova but what chevy made that year in 1970 correct?
#5 | |
Liked 1,883 Times in 423 Posts
The good news is that if you have a 1970 Nova, with a little effort, it can be run as anything between 1968 and 1972. That opens up a huge array of options. There are several good small block combinations, the 255/350 is a pretty good one, so is the 300/350. The four barrel combinations are probably easier to make run, for most people. Although they are more expensive, the 350 and 375 HP 396 and 402 engines are pretty good as well.
Alan Roehrich 212A G/S |
Liked 1,842 Times in 429 Posts
350/250 or a 350/300 combo in a 1970 NOVA is a natural G car.
You can run F-G-H Also you can run a 350 /255 1969 motor and claim your car a 1969 and run the same classes
james perrone 1290 STK |
Liked 905 Times in 193 Posts
Although it's a lot less glamourous, you can run as a '71 with a 250/145 six banger in U or as a '70 with a 230/140 in V. I warn you, though, that itty bitty 1 bbl carb doesn't like bad air. (But it worked for me and still works for Billy!).
