greetings All
can anybody help me with some info in relation to the correct bearing & seal to run on my car it has Lamb struts ( Anglia ) & i have just purchased a new set of front wheels ( Alumastar 788-15000 ) Anglia the issue i have is Lamb list "SPECIAL" bearings for this application the bearings that come with the new wheels are as follows Inner Race: 4T - 07204 - NTN Inner Bearing: 07097-544 Outer Race: 03162 HP Outer Bearing: 03062 Seal is Timken boxed with the part number of 471795 however the seal is marked "NOK AD7127E" what i need to know is, Do i need to buy A: The Lamb "Special" set B: the 07098 Bearing C: the C-R (Chicago Rawhide) 12565 SEAL D: Use what i have been supplied with the wheels the above two part numbers i have found through different forums regards rod |
i would of thought that somebody here would be running the Lamb struts with an Anglia spindle in here ???
regards rod |
i wish i could help you but im sorry i dont know
Good Luck and hope you get what your looking for Last edited by trmnatr; 04-18-2009 at 10:24 PM. Reason: sorry, double post |
#4 | |
Liked 64 Times in 14 Posts
Call Roger Lamb on Monday he will have all your answeres (909) 985-1901
Mark Callanan 1027 STK |
