Old 04-21-2009, 06:45 PM   #11
Chevellewagon
Chevellewagon's Avatar
Default Re: Suspension help
Originally Posted by njk53 View Post
My brother and I have basically the same car as you (Ours is a 71 Chevelle wagon, natural K/SA). The leaning is the result of using a 90-10 shock on the front. Also it is a result of not having sway control as stated by Dragsinger. The leaning is normal. I am assuming that your car leans over when turning and when you get it straight and burp the throttle, the front end will come back to normal ride height. If it stays leaning, there is a problem somewhere in the front suspension mechanicals.
I do have 90-10's on the front and 70-30's rear. Yes once straightening out the car comes back to level. Thanks for the help.
Chevellewagon is offline   Reply With Quote
Old 04-21-2009, 06:51 PM   #12
Chevellewagon
Originally Posted by Dragsinger View Post
the leaning you describe is a basic characteristic for that suspension style. [basically, you have the car sitting on four coil springs with nothing to control "body roll"]
A rear "anti-roll bar" will cure the leaning and make the car overall more stable. It is very likely that a properly installed and properly adjusted anti-roll bar will allow removing the air bags.
Please correct me if I am mistaken, I think a bolt on kit is legal.
Thanks for the help Dragsinger. A rear sway bar might control the handling since the roll bar was added. Down track it wanders a little and sometimes moves left when braking in the shut down area. I am assuming that the roll bar installation lessens "normal" body flex (it's welded to the frame),
Old 04-21-2009, 07:12 PM   #13
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
If you're getting it realigned you had better find out what it was setup to beforehand, at least if you plan to take it to a normal alignment shop, because they'll want to set it to stock specs, and it will likely make your problem worse.
Old 04-21-2009, 08:06 PM   #14
njk53
When you say wandering, are you sawing on the steering wheel or are you feeling the instability in your seat?
Nelson Kowal
Stock 345
Old 04-21-2009, 08:12 PM   #15
72Malibu
72Malibu's Avatar
www.hrpartsnstuff.com bolt on antiroll bar
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 04-21-2009, 09:01 PM   #16
Chevellewagon
Slight steering wheel movement, more like a feeling of the car floating around. It also wants to move to the right when i lift at the top end. Prior to the roll bar being installed it was much more of an easier ride. It used to run nice and straight with a relaxed grip on the wheel.....now I keep a firm grip on it.
Old 04-21-2009, 09:03 PM   #17
Chevellewagon
Thanks for the link. I'll check it out.
Old 04-21-2009, 09:09 PM   #18
Chevellewagon
I am going to have someone take a picture of it at the finish line and figure out how high the front end is and when getting it aligned have the front raised up to that height and set camber at zero,toe as close to zero and caster positive about 5 degrees. Does that sound anywhere near right?
Old 04-22-2009, 08:00 AM   #19
Greg Barsamian
Liked 427 Times in 97 Posts
Phil, I've sold a number of the BMR Xtreme Sway bars to CMDR members.
Check out the pictures from last weekends race @ NED on Actionracingphotos.com
Rick Kagawa is "Dead-On" about Alf Weibe's supension system!
Call The "Golddigger" Jim Boudreau for an alignment!
Old 04-22-2009, 08:17 AM   #20
Chevellewagon
He ought to be able to align it as he bought it from W A Lee in '78. The picture of it on here is with his old paint job still on it in 2000.
Thanks for the info Greg.
