Old 05-01-2009, 06:51 AM   #101
Paul Ceasrine
Liked 10 Times in 10 Posts
Default Re: Whither 1966 D Darts for Stock
D Dart information.
The D-Dart was built in April 1966, in preparation to put cars out there
before the 1966 Sringnationals in June.
The 275 HP rating was advertised by Chrysler, not set by NHRA.
The lb/hp rating factor of the car was 10.71.
The factor ratio of D/Stock in 1966 was, I think, 10.40 to 11.20
The 273/235 HP cars had a rating factor of 12.63.
They fell into the F/Stock class, 12.00 to 12.80.
I might be slightly off on the NHRA factors. Back then NHRA factors
were by .70 or .80, instead of today's.50 factor.
Paul
Old 05-01-2009, 07:58 AM   #102
Paul Ceasrine
D-Dart,
If anyone wants to contact me about D-Dart info and/or several photo's of
an original D-Dart, you may.
e/mail: jvshank@connectnc.net
As for the photo's. I have several from 1971, of a woman racer
named Lori Kane. Her white Dart was lettered Kandy Kane across the doors, with a red and white striped Candy Cane painted in between the
lettering. Her car was sponsored by Garrison Shell, Garrison NY.
D-Dart was painted on the front fenders.
If you look closely at the windows, the car is classed in H/Stock..
From the information that I have gathered, the D-Dart 275 HP rating was
re-factored to 255 in 1971, re-classifieing the car from F/Stock to
H/Stock. Now when NHRA dropped the factoring of the car from stock is still a mystery.
Paul C
Old 05-01-2009, 11:17 AM   #103
Steve Hagberg
Smile Re: Whither 1966 D Darts for Stock
D Darts:
Well I just dusted off my 1966 rule book and discovered a couple of interesting things. First, the classes and weight breaks were not uniform. Stick cars started at S/S, then A/S down through O/S. But the automatic cars stopped at J/SA. The super stock class was 0.00 to 6.99, then as follows: A, 7..00 to 8.69, B, 8.70 to 9.49, C, 9.50 to 10.59, D, 10.60 to 11.29, E, 11.30 to 11.88. and on down the line. How they came up with these breaks is a mystery. Another interesting note is that if your car wasn't in the classification guide, they just weighed your car, subtracted any fuel at 6 lbs/gal and divided by the factory advertised HP, and that was your class. There were no NHRA 'FACTORS' for HP, just factory advertised ratings. So the D Darts fell in the D class at 10.60 to 11.29 lbs/hp. Thsi sure brings back memories of a simpler time!
Steve Hagberg is offline   Reply With Quote
Old 05-02-2009, 10:07 AM   #104
Paul Ceasrine
Steve,
Great job in posting the 1966 stock class factor ratios.
I guess my mind is not that out of tune, I was only off a little on the factor ratios.
If you could, would you give me the factor for F/Stock in 1966.
It started at 11.89, according to your guide, what ratio did it end at.
in 1966 I ran a 66' Barracuda 273/235 HP, and it fell into F/Stock, at the high end of the weight break.
In 68', we ran a 67' Barracuda 273/235 HP that was classified in J/Stock, when the factoring changed. 12.50 to 12.99 for our class.
Thanks,
Paul
Old 05-02-2009, 10:30 AM   #105
Steve Hagberg
Paul:
The F class went from 11.89 to 12.49, and then G stock went from 12.50 to 13.99 seconds. The bad part of the old system, as I'm sure you remember, is that if your car didn't fit in at the low end of the class you just had to carry the extra weight ( you couldn't lighten up to the minimum). Running off the national record was also a problem if you happened to be in a class that had been bombed by a fast car. All these problems eventually led to the formation of Bracket Racing. Interesting that 43 years later we're still arguing over how to make class racing fair.
Steve
Old 05-03-2009, 09:15 AM   #106
Paul Ceasrine
Steve,
Thanks for the F/Stock factor rating. brings back memories of when stock class racing was fun. Bracket racing just took the fun out of us
4-shift stick guys,
Anyway, I found an old Hot Rod magazine with 1966 NHRA info in it.
NHRA's intention in 1966 was to help rate the classes for the new
1966 model year cars, as oppossed to just regular factoring by .50 or
.70. That's why the factor rating is all over the board for 1966.
A/S was to be set for 66' street Hemi's, 327/350 HP Chevy II's,
427/425 HP Biscaynes and 427/425HP Galaxies.
B/S was for 396/375 HP Chevelle's.
C/S was for 389/360 HP GTO's and 400/360 HP Olds 442's.
D/S was for 289/271 HP Hi Po Mustangs.
NHRA's intention was to try to balance out the new 1966 cars into
specific brackets. Of course, everything got messed up over the
years.
paul
Old 05-04-2009, 03:30 PM   #107
dart4forte
My fellow D-Dart friends,
This is what came on the 66' D-Dart 273/275 HP engine.
The block was a standard 273/235 HP HiPo, with a forged steel crank.
The pistons were standard 273/235 HiPo, 10.5-1 compression with a
2-step rise in the piston (Not domed, as some people think).
The pistons were full-floating.
Standard oil pump. (No windage tray or Hi Volume pump)
Standard 273/235 Hi Po steel timing chain.
The camshaft was not a .520 lift racer Brown as some people think. Though Racer Brown did develop cams for the Max-Wedges and
Race Hemi's, they did not provide the camshaft for the 273/275 HP
D-Dart. The camshsft was provided by Camcraft, out of Easton,
Maryland. The lift was .495 intake and .505 exhaust, with a 284* duration. That cam grind was the same Camcraft recommended for their 273 marine performance engines. How they got involved is still a mystery.
The heads were stock 273/235 HiPo, but the valve springs were
Racer Brown, 260lb. rated tension.
Stock steel valve spring retainers.
Amazingly, the stock steel push rod (yes bendable and breakable) were utilized.
The cast iron (YES!) cast iron intake was a stock unit. The carb venturi
holes were bored out from 1 1/2" to 1 11/16" to accept the larger butterfly openings of the Holley carb, The machining of the intake was performed at the factory. The D-Darts that left the LA plant did not require a carb=adapter plate. In general, the low-plane X-runner shape
intake was a piece of garbage. Small runner ports and low-plane was good for low-end torque, but at top-end the air-flow suffered.
The carb was a Holley #4160, 600 cfm vacuum secondaries.
Air-cleaner was specially designed low restriction-type.
Distributor was a dual-point unit, that was modified (vacuum advance unit was removed), to provide for mechanical advance only.
Paul
What I find interesting is that the manifold off the marine 273, the bores are 1 11/16". Had access to one week before last and it measured 1 11/16" so it's possible that's what they used on the D 273.
dart4forte is offline   Reply With Quote
Old 05-04-2009, 03:38 PM   #108
dart4forte
Originally Posted by bill dedman View Post
At some point it looks like there was an aluminum intake somewhere, as it is now legal on the 235HP "Commando" motor (manifold newly legalized), because Angela Bushmaker's K/SA car has one on it, now, and it wouldn't be on there if it weren't legal. She has a '65 Valiant 235HP car.
As to where its original app. was, I don't know. I'm inclined to go with Dwight's information on this, just because everything of that nature was always so "fluid" at MOPAR back then; especially, on a deal like these on again/off again D-Darts. Seems like they made it up as they went along...
It would be interesting to be a fly on the wall at the Bushmaker garage when they discuss how they ran using that intake. The Edelbrock D4B was a factory over the counter replacement intake for the 273/318 starting in 66. I have several so I'll look at the part numbers and post it.
Old 05-16-2009, 12:56 PM   #109
ddartdude
Well.......my old D/Dart is going on the Mecum auction block in about 4 hours. Any guesses as to what it will bring? At the price range listed in the Ellis Brochure, I doubt if it will sell. If nothing else, it will be a TV Star.
ddartdude is offline   Reply With Quote
Old 05-28-2009, 09:52 AM   #110
Sean Haning
Sean Haning's Avatar
Send a message via AIM to Sean Haning
I just saw a thread somewhere the other day on, I'm guessing your car. It was apparantly a no sale at an auction somewhere. The pictures of the car were amazing, what a neat piece of racing history!
Hired gun w/o gun.
Sean Haning is offline   Reply With Quote
