Old 05-05-2009, 11:30 AM   #11
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Default Re: th400 second gear intermitent
Greg,I'm assuming you are using the smooth race 34element sprag. ....It's very unlikely you hurt the sprag, altho I've had one or two spin the inner race on the direct drum.......? are you using an aluminum drum?,very possible to spin a race on some of them ....Hard to find since the race is pressed onto the splines on the drum. ....Other than a sheared center support bolt,which feeds second gear, Id be looking at the valve body.....Tom
Old 05-05-2009, 12:15 PM   #12
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
its not a 34 element ,we counted 17,but the replace ment will be the 34 element one ,that could be the issue gmonde
Old 05-05-2009, 01:37 PM   #13
Henry S
Liked 19 Times in 7 Posts
What rings are you using for the center support? teflon or steel? I had a similar problem where a teflon ring was smashed in the ring groove. caused similar problem i think it was temp sensitive, hot would fail, cold was ok. Good idea to replace the cable regularly.
Henry S is offline   Reply With Quote
Old 05-05-2009, 06:05 PM   #14
gmonde
gmonde's Avatar
teflon rings and they looked good they where not stuck in the grooves,but if it was a presure issue i would think it would show in the clutch pack, burned or marked clutches and or steels gmonde
Old 05-05-2009, 09:02 PM   #15
Tom Goldman
The sealing rings on the center support are for the direct clutches and the sprag lube circuit ....they dont affect 2nd gear. ...... .the intermediate brake clutches in the case are actuated thru the center support anchor bolt....400's have been prone to sealing ring issues at the center support for years . ....some prefer teflon tings, others hard chromed iron rings. both work well when the drum stays off the ring lands ......ATI has a modified support with a floating bearing machined between the ring lands that helps support the weight of the direct drum, and keeps it from dragging on the ring lands ,which is really important with a stock iron drum at high rpm.,altho you really should have an aluminum direct drum for your application. ......Tom
Old 05-05-2009, 10:14 PM   #16
west coast
Liked 227 Times in 74 Posts
It is your sprag if it does not hold no second gear. You said you have a 17 element which is stock they do not hold up to alot of power a couple of people make the double elements I used the Hughes never had another problem had to do it on a friday night at a divisional in Seattle. The tell tale sign of this is you hit the chip. I have ran S/G and S/ST for years with this combo.
west coast is offline   Reply With Quote
Old 05-05-2009, 10:59 PM   #17
Jeff Stout
Liked 706 Times in 283 Posts
The $2.00 snap ring that holds sprag in place is broke. I just went through this 3 months ago.On the street it worked great but twice at the track no second. If you guys watch Passtime my car is the Monte from the episode of AZ Fastest street cars in which it had no second and I thought I put it into neutral from coming down from a large wheelie.Sent meatl trash throughout the whole trans.
Jeff
Old 05-05-2009, 11:06 PM   #18
SS Engine Guy
When the sprag rolls it does not come and go in my experience. Stock sprag is really bad about rolling the elements. Should roll one way but not the other. Good call on the snap ring/spiral ring holding the sprag. Back when we ran 400's the ring was tigged in place.
SS Engine Guy is offline   Reply With Quote
Old 05-06-2009, 06:39 AM   #19
gmonde
gmonde's Avatar
the snap ring was in place,i will upgrade the sprag to the 34 element ,and try it out ,like mentioned it all looks real good ,no metal chunks,presure testsed the clutch pack for clamping presure ,checked detent for valvebody spool operation,tom your right should have the aluminum drum, but it is not in the budget for this month,thanks for the replys ,all of the info very helpful
gmonde
Old 05-06-2009, 07:43 AM   #20
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
If your 2nd sprag has been slipping, it probably has hurt the surface finish on both the inner and the outer races. The surface finish is critical to the ability of the sprag to hold torque. The outer race is easy to replace. The inner one is ground true after being pressed on the drum, and should not be replaced. Best practice is get a different/new drum that is in good condition. Also make sure you get a 400 drum instead of a 4L80-E drum. The balance procedure on the 4L80 part might have compromised it's ability to be able to spin at high RPM. OK for a truck, iffy for a race car.
