Go Back   CLASS RACER FORUM > Class Racer Forums > Competition
Old 05-03-2009, 07:26 PM   #1
71plymouth
71plymouth's Avatar
Question super modified
i have a nhra rule book but i am confused about the chassis rules. i have a 71 plymouth scamp. can i use a bolt in tubular K member and a arms? also do i have to run the stock rear suspension of can i use a 4 link? and my last question is: i have a 358" dodge R5P7 nascar motor, can i run that in super modified?
-thanks for the help!
71plymouth is offline   Reply With Quote
Old 05-04-2009, 10:52 AM   #2
71plymouth
71plymouth's Avatar
Default Re: super modified
no one can help me?
Old 05-04-2009, 06:41 PM   #3
Bob Lasko
Bob Lasko's Avatar
Liked 186 Times in 55 Posts
you have to run a stock front suspension, and can use a 4 link in the rear
bob lasko
ss/cs
Old 05-09-2009, 10:42 PM   #4
RJ
The R5P7 block/heads have factory part numbers on them, yes you can use the engine. Let me know if you need any help, I have a little bit of background with those engines.
RJ is offline   Reply With Quote
Old 05-12-2009, 10:38 PM   #5
herbjr
Liked 83 Times in 32 Posts
I think SSBM would be a better deal. Im building one of those.
herbjr is offline   Reply With Quote
Old 05-12-2009, 11:16 PM   #6
RJ
The P7 head was designed with 11 degree slanted ports for a single carb, but they also do work well with the intake ports straightened out, a sheet intake, and a pair of dominators. One of those in Bocephus would be bad azz.
Old 05-13-2009, 06:47 AM   #7
herbjr
Well I have a GT car for it, but now that you mention it. Lets See 850 Hp at 3700 lbs. I can get that car to 3450 in SS trim, that is sick to think about.
Herb Jr
Old 05-22-2009, 11:50 AM   #8
71plymouth
71plymouth's Avatar
you can run a sheet metal intake and twin dominators? i didnt know that that was legal!
Old 05-23-2009, 04:57 AM   #9
RJ
I was referring to Herb's post about running in the SS/BM class, that class can run the 2 dominators. You can run a sheet intake in super modified, and you should, even with the single 4 barrel. If you are serious about this, PM me and I'll help all I can.
Old 05-25-2009, 09:24 AM   #10
herbjr
no one can help me?
Private message me I can help.
