Old 05-26-2009, 11:31 PM   #21
Liked 1,924 Times in 432 Posts
Default Re: Aubrey's 62 409 goes 11.067 in C/S
It would not be hard at all to put the brackets on a 12 bolt correctly, honestly, the geometry is not all that complicated. The 12 bolt would be cheaper, faster, and more reliable. It just would not be as cool.
I seriously doubt there is a cost effective way to keep the original rear end in the car and have it be reliable. Much as I'd like to see it work, it would be pretty cool.
Old 05-27-2009, 10:21 AM   #22
treessavoy
Liked 4 Times in 4 Posts
I agree with Alan.
Any chassis shop can set up the correct angles for the 12 bolt in your car.
You might get in contact with some of the rear end builders...strange, moser, dts, or Randy at www.ringandpinion.com, perhaps one of them can help you.
Keep her running.
Jim
Old 05-27-2009, 01:56 PM   #23
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Thumbs up Re: Aubrey's 62 409 goes 11.067 in C/S
As usual... excellent points and suggestions.
There is apparently, a simple 12 bolt conversion available. I just don't like conventional 10/12 bolts, what with their need for "c clip eliminators", ect. A person still needs a spool, axles, cap supports... and those elusive ( to me ) 9310 "pro gears".
My beautiful disc brake adaptors turned out so nice, that I just can't abandon them yet !
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 05-27-2009, 03:32 PM   #24
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
You do not have to run c-clip crap, just change the ends on the housing when you order axles, 12 bolt will come no matter what. Its like 8 .75 mopar rears, your going to get a dana no matter what you do.
Bob Pagano A/SA
Old 05-27-2009, 05:37 PM   #25
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Aubrey's 62 409 goes 11.067 in C/S
I swapped in a 12 bolt into my red 62 Impala SS back in 1976 with no problems. It originally was from a 69 El Camino, so ALL 68-72 A body 12 bolts will work.As I recall, the back spacing was not an issue,backing plate to backing plate,I used 4.56 gears,nothing trick here, a 4 series posi unit and stock axles.The 65-70 Impala unit was about three inches wider and would have to be narrowed.The 65-up lower control arm brackets could be removed from the 62 housing and welded to the 12 bolt axle tubes. I think that the brake backing plates might interchange from the 62 rear end to the 65,therefore your disc brake stuff would carry over to it. The upper arm attachment points on the 65 impala 12 bolt might have to be moved a bit to line things up, and some kind of custom length Panhard rod would have to be built-no big deal. In order to put the stock width Chevelle A body rear end in, the 62 lower arm brackets would have to be swapped for the Chevelle arm brackets then some kind of custom upper trailing arms would have to be made to connect the upper arm front mounting point to the Chevelle upper bushings. NHRA rulebook says that the rear upper arm mounting point CAN be relocated. Wonder if they thought of these cars when they made that rule!One thing,though- A body cars had 9 1/2" dia.rear brakes-also,the flange for the backing plate was smaller as they had a smaller diameter axle than the big car 12 bolts.One thing for certain-the 12 bolt is the way to go with these cars,there's no shortage of good parts out there for them.
Old 05-28-2009, 01:53 PM   #26
ss wannabee
Liked 7 Times in 7 Posts
I think Aubrey's trying to get the Bubbletop into the 10's WITH the 10-bolt if he can. Wonder if dropping down to 4.88 would give you any strength and not affect the tune-up too much? 12-bolt is probably the way to go long-term...I think it's legal now...didn't that '62 Vette Stocker in Div.1 have one aboard a few years ago when it came out? But the Bel-Air would loose some of it's coolness if the rear was swapped, LOL!!! I'd check the 10-bolt banjo housing when doing repairs to make sure it's not distorted any...isn't it basically sheet-metal? Wonder if a little more clutch work would allow the 10-bolt to "live" a bit longer? While we're on the subject, would anybody know how many '62 Bel-Air Bubbletops were built...do I understand about 5900....and about how many were ACTUALLY 409 factory-equipped??? I've heard some of the stories about the '62 Indy Nats, and the late(in the model year) release of the aluminum front-ends and Z-11 parts upgrade and some of the racers 'borrowing' Bubbletop pieces (or cars) from rental car agencies...or so forth...All I can say is WISH I were there! Must have been a wild time!!!!
ss wannabee is offline   Reply With Quote
Old 05-28-2009, 02:17 PM   #27
Tony Janes
The 10 bolt drop out is a waste of time if he is serious. It will break almost every time he goes to an event. 12 bolt 35 spline spool and axles next step.
Tony Janes 7941 STK, SS
Old 05-28-2009, 08:52 PM   #28
Jackie McCracken
Guest
Posts: n/a
Aubry,
Your car makes me smile! I'm glad to see that you’re getting it there. Don't listen to the naysayers, you've got a plan that is working stick with it!
Jackie McCracken
Old 05-29-2009, 01:07 AM   #29
Ken Haase
Aubrey, your BelAir was undoubtedly the crowd favorite at Mission. And I'd bet those fans were plenty disappointed when the rear let go. But, not nearly as much as you were! I don't think Tony Janes is being a naysayer. I think that he is giving very good advice. As far as 'cool' goes, the only people that will know there's a 12 bolt under there are you and whoever wants to get down on the ground and look. IMO, cool is those disc brake mounts you made. Those were an upgrade, and a smart one at that. I understand the reluctance to give up on the original 'chunks'. But, you're making good power, you've got a fairly deep first gear, and using a clutch. Recent history proves Tony's point don't you think? When you stage at the next race you go to, you're going to have that nagging little voice saying "is it going to break again?" With a 12 bolt there's more ratio selection, parts availability, and the strength factor. Just another smart upgrade.
Personally, I want to see that car go rounds, not be towed off the starting line. No rear is bulletproof, but you would really improve your odds. Best of Luck.
Ken Haase is offline   Reply With Quote
Old 05-29-2009, 10:36 AM   #30
Greg Reimer 7376
Ken is exactly right. Also,the collector/restorer's demand on the early rear end's parts availability has the cost of those units up to where a good 12 bolt isn't that costly by compatison.We all want to see that car go rounds,this would help it immensely. Bring it down for Winternationals some year!
