Old 05-27-2009, 08:55 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1968 L78 396-375HP Engine
I have a standard bore 396 4 bolt block casting number 3935440 dated F-10-8. The block was cleaned and magged and I have a new set of speed pro dome pistons with a new set of rings to go with it. I also have the 3919840 heads all redone dated F-17-8 and F-18-8 along with the 6223 crankshaft ready to go. The motor will also come with new freeze plugs, crank bearings, 3/8 rods, new factory style dipstick and new high volume oil pump. The block is apart for inspection and will take $4,000 for this set up and can ship this motor if you cannot pick it up. I can be reached at 330-770-2517.
dlv4540 is offline   Reply With Quote
Search this Thread:
Advanced Search
