Old 06-02-2009, 03:24 PM   #11
Sean Haning
Sean Haning's Avatar
Send a message via AIM to Sean Haning
Default Re: Cal-Tracs Equipped Car "bucking" on launch
While I've never tested what I was told, I was told not to put traction/slapper bars on my Mopar because the front spring eye was too far forward and the bar would push behind it and cause a spring issue. Before John came out with his setup all I ever used were S/S springs, with solid front bushing and an adjustable pinion snubber.
Hired gun w/o gun.
Sean Haning is offline   Reply With Quote
Old 06-02-2009, 03:26 PM   #12
herbjr
Liked 83 Times in 32 Posts
Hell my dad ran 4 speeds for years with Ladder bars and leaf springs. Went 9.00 150 with a Hemi and a 4 speed. Guess you cant run leafs with bars.
haha
herb jr
herbjr is offline   Reply With Quote
Old 06-02-2009, 06:46 PM   #13
Sean Haning
haha
herb jr
LOL, might have gone 8.99 and 151 w/o leafs.
Hired gun w/o gun.
Old 06-02-2009, 08:37 PM   #14
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Thank you all for contributing.
I think a call to Travis at Calvert Racing will be in order.
Chad
Chad E532 is offline   Reply With Quote
Old 06-03-2009, 11:05 AM   #15
Dave1695
Liked 15 Times in 11 Posts
changing from lower to upper hole changes instant center location, go back to the lower holes, start shocks on number 2 and stop binding the suspension with so much pre load.
Dave1695 is offline   Reply With Quote
Old 06-03-2009, 09:45 PM   #16
ericsz
Lower hole will soften the hit. Tighten up your rear shocks, I run the ranchos they recommend with my bars as level with the ground as possible. Just my 2 cents..
Eric Bowling
ericsz is offline   Reply With Quote
Old 06-04-2009, 05:30 AM   #17
bobby
bobby's Avatar
I had actually built a set of bars like the caltracs. I ran the bottom bar level with the ground. after running these for 10 years, the right rear stock leaf spring decided it didnt want to go down the track anymore, so I put some ladder bars and coil overs on it.
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
Old 06-04-2009, 12:27 PM   #18
OLDGOAT
OLDGOAT's Avatar
Originally Posted by Chad E532 View Post
I am having some problems dialing in my car now that I have installed the Cal Tracs mono leaf springs and bar setup. The car launches and then as soon as the front end is up on the stops the car seems to rock or buck front to rear 2-3 times before straightening out. We have tried the upper and lower holes and also played with shock settings. I went to a longer travel rear shock thinking I was running out of travel but that does not seem to be the case. I have been able to minimize the action but it does not go away completely. Right now I am running 3 clicks on the rear QA1 shocks (single adjust) with the Cal Tracs in the bottom hole with 1/4 turn of preload each side with driver in car.
The front end has the AFCO bushings, Moroso trick springs, and Cal Tracs 90/10s giving me 4.5" of front end travel. I am running 30x9 Goodyear radials and tried 20 psi and 18 psi with 18 giving me a slightly better 60' but still rocking.
My father also recently put the mono leafs and Cal Tracs on his car and is seeing similar bucking but not to the level that I am.
Thanks in advance for any help you can provide.
Chad
Can you get 5-6" ? That is what was suggested for my car.
OLDGOAT
OLDGOAT is offline   Reply With Quote
