Old 06-03-2009, 09:31 PM   #1
partsbob67
Liked 79 Times in 11 Posts
Default ford 5.0 spark plug recomendation
what plugs do you guys recomend for a stockker application? i've been running motorcraft number asf 42c, with phillips tt100 fuel. should i change? plugs always look black and sooty, but my wideband shows i'm lean or better. thanks in advance.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 06-04-2009, 08:21 AM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: ford 5.0 spark plug recomendation
Just a dumb question? Where is your O2 sensor mounted? An exhaust leak will give bad readings. If you have the O2 sensor mounted next to the collector, you could be getting a diluted reading also.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 06-04-2009, 09:15 AM   #3
partsbob67
down by the collector, but i run an x-pipe and mufflers.exhaust dumps right before the axle, so i don't think it is getting diluted.
bob beals 7244
Old 06-04-2009, 09:57 AM   #4
buzzinhalfdozen
Liked 11 Times in 8 Posts
By lean on the wide band you mean?.......What's the AFR? And does it show lean at idle? Have you looked at the sensor to see if it is sooty, I've seen 02sensors get sckewed and give false readings, just some thoughts. Joe
Joe Buchanan SS/BX 3117
Old 06-04-2009, 06:27 PM   #5
partsbob67
thanks i'll check the sensor.
bob beals 7244
Old 06-04-2009, 07:05 PM   #6
7423
Bob
Check your PM
7423 is offline   Reply With Quote
