My 1994 C/S Camaro is finally together and running. I saw the thread on in car valve spring tools and was looking for a good in car valve spring tester for the late model Camaro's. With the engine set back under the cowel, I don't think a conventional tool would work. What works in this application?
Cam |
The LSM low profile one should work. You can check it out on their web site.
Bill Edgeworth 6471 STK |
Liked 53 Times in 13 Posts
I have the moroso low profile tester and there is no room what so ever for the back 4 cylinders. I don't think the LSM unit will fit either. I have a 93 super stock firebird and it's not fun to check springs on the back 4. It's easier to pull the motor out and do your check...Luke
Cam .. good to hear you got it running ... no devastating launches this time I hope . Call me
Mike 403-304-3536 |
#5 | |
Won’t the LSM one with the short handle fit? Although in an SS motor it would be tough to pull enough pressure to check the seat pressure even if it fits its underneath the cowl with the short handle. I think a while back there was a thread where someone with one of those cars mentioned he had an LSM and made a custom offset handle for it or possibly broached the handle so he could apply torque to it with a ratchet and extension from outside the cowl area. Check out the LSM one at; http://www.lsmproducts.com/photo/pro...l/pc100slc.jpg
Liked 553 Times in 216 Posts
I re- read your post and realized you were looking for a tester....not a remover. I don't know what on the car tester would work as there is very little room at the rear of the engine. I changed mine due to some broken dampners.....You can change a complete set in a couple hours tops with the KD tool......
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 06-03-2009 at 04:40 PM. |
Thank you for the replys. I'm waiting to hear back from Logan. I will post the info I get back.
Cam |
Rich:
I ordered the KD tool. Nothing back from LSM yet. Cam |
Cam...you can easily remove the springs with that tester and check them with a bench tester. I have only used the Moroso on car spring tester in the past and it is not even close to being accurate. We used it as a way to look for very obvioulsy weak springs or maybe a broken inner on roller cam springs. I know the LSM stuff is very good but it's going to be very difficult to use something on the springs under the cowl of any late model LT-1 Stocker. I was doing a leakdown test on my engine and looking over the valvetrain one day and found I had broken a bunch of dampers. I think it was from a poor fit between the dampers and the ID type spring seats I had used.
