Old 06-12-2009, 08:01 PM   #1
doglover44
doglover44's Avatar
Liked 492 Times in 230 Posts
Default Turbo Action Cheetah Shifters
does anyone use them what is the good and bad on these ? are they worth getting ?
Old 06-12-2009, 08:27 PM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: Turbo Action Cheetah Shifters
i love mine , and have owned a few over the years. there simple and reliable. and IMO the only choice for a 3 speed air shifted application.
Mark Markow is offline   Reply With Quote
Old 06-12-2009, 08:37 PM   #3
mannymen
Liked 13 Times in 7 Posts
If you are shifting manually and run a 10 second or faster car and leaving off of a transbrake, then it is not the shifter you want. In a reverse pattern 3 speed I don't like how loose (non-positive) between neutral and 1st it is. I have to bump the transbrake just to make sure it is in first and not somewhere in between and my detent is firm. Also when footbraking anothers car I was (reverse T-400 also) resting my hand on the shifter preparing to shift, but before launching and when I launched the 11 second car the inertia barely pulled my hand shifting it into 2nd right off of the line. I like a firm ratcheting shifter that I have to crank back and not a loose feeling shifter. This is just from my experience as I'm sure it works for many others. I hate shifting a 3 speed, so I guess that's how one feels when you raced with a powerglide most of your life
N/A
mannymen is offline   Reply With Quote
Old 06-12-2009, 09:02 PM   #4
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I had one in my 97 Firebird stocker with a reverse pattern 200 trans that I manually shifted. I did not like the shifter and the reverse pattern trans did not match the gate so I had to use 3 motions to shift twice. A forward pattern valve body would have made it a much better feel and then the shifter and trans would have been fine. I was going to install the e-shift but never got that far.....For a 3 speed I would say it is a very good shifter......I would not use it with a powerglide.....
Rich Biebel
S/C 1479
Stock 147R
Old 06-12-2009, 09:26 PM   #5
SPS
Liked 3 Times in 2 Posts
An excellent shifter especially for a 3-speed. One of the only ones that use one air cylinder to shift both gears.
We make some small modifications to ensure accurate and consistent shifts without over-shifts.
We also modify it for second neutral, air shifted trans's.
We have used it a lot in our own cars as well as customers and it never fails. Shifts are very accurate as far as RPM's.
FJ
SPS is offline   Reply With Quote
Old 06-12-2009, 11:32 PM   #6
SS Engine Guy
Best 3 speed auto I have used with air. Extremely accurate if the correct arm is used on the trans. BUT....if the "buy one every 4 years or no contingency" still stands I won't own another one. Always one of the first to pay and great product and service.
SS Engine Guy is offline   Reply With Quote
Old 06-12-2009, 11:49 PM   #7
Talking Re: Turbo Action Cheetah Shifters
We have one in each and every car -- Paul Forte has been my friend and trans company for longer than I can remember and I wouldn't race without his products in my car -- their shifters are the best in the business -- period .
Old 06-13-2009, 07:59 AM   #8
RJ
Is this a Turbo Action or NHRA rule?
RJ is offline   Reply With Quote
Old 06-13-2009, 11:02 AM   #9
Everett Vassar
Liked 2 Times in 2 Posts
I agree with mannymen I was disapointed with this thing at first Because there is no positive mechanical ratchet for the gear positions.I make damn sure its in 1st before I stage.Then I can just slap it back going down track (727 rev) Its a little like the best factory shifter ever made-- the Mopar Slap Stik So I guess thats why I bought it.
Everett Vassar is offline   Reply With Quote
Old 06-13-2009, 12:28 PM   #10
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
I have them in my stocker dakota, my bracket/backup stocker 70 challenger, my 78 lil red express 440 toy....only the 72 stick challenger doesn't...cut it would if it they made one.... the 93 dually would love the upgrade....
Kidding aside, look around in the staging lanes at a divisional or national event. You will see legions of them. They just work! Jack is right.
Eric
Eric Merryfield 1883 STK
