Old 06-15-2009, 11:41 AM   #11
Chris1529
Liked 70 Times in 29 Posts
Default Re: 5.0 stocker rear control arm bushings
I have not heard of the polyeurethane bushings causing movement, but they may. Do the bolts that go through the bushings fit tightly? If not, you may need to look at putting larger bolts on the car. That may be where some of your movement is originating from.
You really need to get the subframe connectors and do some work on the torque boxes too.
You will be surprised at the difference in the way the car feels after installing the frame connectors.
What kind of 60' times do you have with this car?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 06-15-2009, 01:44 PM   #12
west coast
Liked 223 Times in 73 Posts
My control arms look like a BMR with spherical bearings I believe these are the bearings I used http://www.midwestcontrol.com/buy.php?item=2412 I then made the bushings that fit to use a 1/2" bolt for connecting it to the torque box and the rear end. My torque boxes have been renforced also.
west coast is offline   Reply With Quote
Old 06-15-2009, 01:51 PM   #13
Tim Ellis
Liked 7 Times in 6 Posts
The car 60 fts 1.62- 1.65.Last weekend 1.637- 1.647 in 6 runsThe car is down on horse power for whatever reason, only mphs at 101+-
Tim Ellis is offline   Reply With Quote
Old 06-15-2009, 04:30 PM   #14
larry dowty
Liked 11 Times in 4 Posts
Tim are you coming to seattle this weekend ? we could talk about you problem.
larry dowty 6388 SS
larry dowty is offline   Reply With Quote
Old 06-15-2009, 04:34 PM   #15
Tim Ellis
hi Larry,I'm thinkin about it, but beings that its fathers day Im not sure
Old 06-15-2009, 06:52 PM   #16
Tim Ellis
I'm tryin to show some pictures here, you can see how much things are moving by the grease smudges in front and in back of the bushing
Old 06-15-2009, 07:25 PM   #17
Tim Ellis
oops, didnt work, try try again
Old 06-15-2009, 07:27 PM   #18
Tim Ellis
again.
ID:	926   Click image for larger version
Old 06-15-2009, 07:53 PM   #19
Chris1529
I really think the bolts are too small, or the mounting holes are elongated. I don't think changing bushings will help you out. I have UPR's on mine with poly bushings and they don't move.
Chris Bowman
1984 Mustang GT350
Old 06-15-2009, 08:39 PM   #20
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
If they are moving that much, WOW!!! If the holes are enlarged. The quick fix is to weld a washer of the same diameter as the hole that you have through the control arm. You just need to make sure everything is square first. Something is very wrong.
Sean
Sean Marconette
84 Mustang
5060 SS/N
