Old 06-15-2009, 08:41 PM   #21
west coast
Liked 223 Times in 73 Posts
Default Re: 5.0 stocker rear control arm bushings
Looks like you found the next weak link. Thats alot of movement mounting holes must be elongated. I take it this a 5 speed car.
west coast is offline   Reply With Quote
Old 06-15-2009, 08:44 PM   #22
Jim Foley
Jim Foley's Avatar
Tim I went through the same problems as you if not worse. I have an 88 K/SA Notch and would be happy to tell you what my fix was. I got some good advise from Evan Smith through my friend that really changed the car. I went from 60" of 1.59 to 1.54 every run and from 12.teens to 11.82 last weekend. PM me and I'll give you my number and hopefully I can at least tell you what fixed my car.
Jim Foley is offline   Reply With Quote
Old 06-15-2009, 10:08 PM   #23
Tim Ellis
Liked 7 Times in 6 Posts
POLY USERS BEWARE!!! check this out, thanx guys, still let me know which arms you use ,if you use alum or dela lum bushings. I might order a set of the global wests tomorrow. By the way its just a slow 12.70- 12.80s 3400 lb+ o/sa car
ID:	928   Click image for larger version
ID:	929   Click image for larger version
Tim Ellis is offline   Reply With Quote
Old 06-15-2009, 10:36 PM   #24
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
back in the day moroso/comp eng. use to sell the alum. bushings. thats all i have on the lower arms and there boxed in. the problem with them were, once you tightened the bolt it would lock the rear suspension up...easy fix, bore the bushing and put a sleeve in it also narrowed it up about .065 on each side. the upper arms are home made and it all works lovely together.. not sure who makes the alum bushings anymore but any industrial machine shop should be able to fab them up for you. have no idea how much it would cost tho. hope that helps...BTW the torque boxes are also welded up uppers and lowers.
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 06-15-2009, 11:44 PM   #25
slamming 6
If you let me know the I.D. solid bushing you need I can send them to you. these are solid aluminum with steel sleve.Dont worry the price is right,just pay the shipping.Take Care,Al.
slamming 6 is offline   Reply With Quote
Old 06-16-2009, 03:30 AM   #26
87gt50
Jim,
It would be really interesting to know what you did. My 60foot is in the low 1.7 range with car in N/S configuration, still running the stock t-5. Local track being 1/8 mile, it usually runs in 8.0s, but I have "bouncing" issues off the line that I believe seriously hurts the 60foot.
Any advice is welcome btw!
Tim, I'm glad you found the issue. Looks like an upgrade is in place!
87gt50 is offline   Reply With Quote
Old 06-17-2009, 01:01 PM   #27
Tim Ellis
Slamming 6, thanx for the offer, I might take you up on it later.Im gonna order some alum bushing lower control arms from upr...I think
