Old 06-16-2009, 07:36 PM   #21
Ed Wright
Ed Wright's Avatar
Default Re: Enclosed Trailer Recomendations
I have been really happy with my 24' ATC. Light, nice fit & finish, tows great. Tows even better now that I put 16" wheels on it with 10 ply tires that use 80 psi. Made more difference than I expected.
Ed Wright 4156 SS/JA
Old 06-16-2009, 08:11 PM   #22
CBS
CBS's Avatar
Liked 4 Times in 2 Posts
Certainly anybody with a T& E will tell you that they are the finest....Just check one out at the track.....the resale is great....and it will last.....Fletchers is a T&E...with a zillion miles on it...T&E will also repair trailers of all makes.....and you guys will all love the customer service and quality...buy one and be sure....instead of hoping....
Rock Haas
CBS is offline   Reply With Quote
Old 06-16-2009, 08:30 PM   #23
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Thanks everyone for the input. I would not have thought to order the 16" wheels / tires as an option, but plan on it now no matter what brand trailer I end up with.
Has anyone had any experience with the Team Spirit trailers or the Bruce Litton (united) Trailers? I saw a few of these at the track last time and the fit and finish looked good, but I am not sure if they are built sound or not.
Thanks,
Chad
Chad E532 is offline   Reply With Quote
Old 06-16-2009, 10:52 PM   #24
John Kelley
Chad
You should check out the thread about trailer tires ! Some guys run even bigger tires like 17.5 inch
It'd be worth the safety factor to me......
John Kelley is offline   Reply With Quote
Old 06-17-2009, 04:16 AM   #25
Larry Munk
The other guys covered all the important stuff. The most important being weight and pruchasing the largest heavy dutiest tire,wheel and axle available. Do yourself a favor and see if someone will let you pull a trailer of the desired size with your rig. Then go home and sleep on it for a while before you decide on what you buy.
Larry Munk is offline   Reply With Quote
Old 06-17-2009, 05:29 AM   #26
bobby
bobby's Avatar
Best advice.
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
Old 06-17-2009, 10:50 AM   #27
John Kelley
This is the thread about tires......good info
http://classracer.com/classforum/showthread.php?t=17114
Old 06-17-2009, 10:59 AM   #28
John Dinkel
Liked 263 Times in 68 Posts
Buy the biggest axles and tires. You won't go wrong.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 06-17-2009, 12:21 PM   #29
63corvette
Liked 359 Times in 103 Posts
John Dinkel Quote:
There is one issue you also want to think about on the biggest axles.
Do get the heaviest tires available, you won't be sorry there.
It is little known law about the total GVW on the rig you drive.
If the total GVW (Truck and Trailer GVW added together) exceeds 26,001 you need a class A or B license or a CDL if it is a commercial operation.
The GVW of the trailer is usually set by adding the total carrying capacity of each axle or is sometimes reduced by the trailer manufacturer if the frame is not rated to match the axle capacity.
I know this is a law not enforced very often but it is there.
A 1 ton dually and a fairly small trailer will have the GVW over the limit.
I went ahead and did get my class B last week after being in violation for the past 8 years and not knowing.
Just something to think about.
My 2 Cents
63corvette is offline   Reply With Quote
