Old 06-18-2009, 07:31 PM   #1
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default recomended presures in radial slicks
there seams to be no recomended presures for the radial slicks,i have a new set of hoosiers 9x30r car weighs 3665 with the driver ,,,,i run 16 psi in the bias ply 29.5 x 9 with good results just looking for some comparison with simular weight cars gmonde
Old 06-18-2009, 07:42 PM   #2
Curt Rees
Liked 251 Times in 51 Posts
Default Re: recomended presures in radial slicks
18 pounds at 3400.
#5457
Curt Rees
Curt Rees 5457 SS
Curt Rees is offline   Reply With Quote
Old 06-18-2009, 08:14 PM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: recomended presures in radial slicks
Lots of variables, including car weight, weight transfer, suspension hit, rim width, etc.
I have the Hoosier 9" lightweight radials on 10" rims, car weighs 3,540lbs + and I footbrake. I've been running 21 lbs. of air. It's been a while since I ran the car over 3,700 lbs, but I don't recall changing the pressure then.
LOCOMOTION Racing
Old 06-18-2009, 08:15 PM   #4
Ron Zenzen 5402
Smile Re: recomended presures in radial slicks
Our Deal, 22 PSI
Ron Zenzen 5402 SS
Ron Zenzen 5402 is offline   Reply With Quote
Old 06-18-2009, 08:20 PM   #5
nwebber
Liked 39 Times in 5 Posts
I run a 3600 pound wagon with a 305 and can run up to 35 pounds without any issue.
Norm Webber
LSA 6635
Norm Webber
nwebber is offline   Reply With Quote
Old 06-18-2009, 08:36 PM   #6
George Mirza
Start at 20lbs and go up from there. Talk with some of the guys running coil spring cars, they can tell you what will work.
See you at LV
George
George Mirza is offline   Reply With Quote
Old 06-18-2009, 09:30 PM   #7
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Exclamation Re: recomended presures in radial slicks
I have been running 22lbs. with 30X9 Hoosier light weight radials in a 3500lb. Stocker with CalTrac leaf suspension. Jim
Old 06-19-2009, 05:12 AM   #8
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
3560# chevelle, 25.5 pounds on an 8 inch rim
Ian
Ian Hill is offline   Reply With Quote
Old 06-19-2009, 05:14 AM   #9
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
I agree. 30X9 Hoosier (CO7) radials 19-22 lb 3500 lb foot brake. Depends on track
Old 06-19-2009, 07:58 AM   #10
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Been running Hoosier's 30 x 10.5 radial slick on my nose heavy 3880 lb. BB Chevelle since the 2000 season using 3 pairs a season, pulling them off at 75 passes and typically aired to 18 psi.
Have gone 100+ passes on a set and I've run them with as much as 20 psi.
Have gone a best of 1.28 60 foot and 1.36 60 foot breaking the beam with the back tires.
My rule of thumb is to start at 5 psi more than what you ran with bias slicks.
