Old 06-19-2009, 07:50 PM   #11
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: recomended presures in radial slicks
thanks for the advice ,,getting ready for the divisonal at lebannon valley see you there thanks gmonde
Old 06-23-2009, 08:16 AM   #12
ss wannabee
Liked 7 Times in 7 Posts
You guys make an "adjustment" when the air become hot and soupy like in summer?
ss wannabee is offline   Reply With Quote
Old 06-23-2009, 11:30 PM   #13
Marvin Robinson
Marvin Robinson's Avatar
I'm running the liteweight Hoosiers, 92.5 X 9.00 hard compound @ 21psi on F/SA 71 Olds 442. I have 20 psi in rt airbag, 5 psi in left. Seems to hook OK, but I'm working on the power end of the equation right now.
I would like to know what you have for the A-Arms and links in the front suspension, I need my fronts to hang straight like yours, not splayed from camber change.
Thanx,
Starvin Marvin 3188
Marvin Robinson is offline   Reply With Quote
Old 06-24-2009, 10:58 AM   #14
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
36 PSI in my 4400 lb. stocker
Bob Bender 144 O/SA
Old 06-24-2009, 04:02 PM   #15
treessavoy
Liked 4 Times in 4 Posts
I bought my 9" radials from Hoosier at the track and their rep's said to start at 21lbs for my 3450lb Ply.
Old 06-28-2009, 04:03 AM   #16
Footbrake
Footbrake's Avatar
Not radials but maybe you guys can help me out here. I run 26x10 Hoosier slicks. I had my 7" cutlass rallys widened to 9" for a better footprint. Now I don't know where to go as far as air pressure. My 9" slicks on 7" rims liked about 18lbs, but these don't. It hooks the best at about 12.5 lbs. Am I going in the right direction or should I try a lot more air in these slicks? Car with me in it is 3960lbs.
Footbrake is offline   Reply With Quote
