Old 06-23-2009, 08:49 PM   #1
Z28-69
Default Ball Joint's of choice?
Can you guy's give me some opinion on ball joints of choice for the first gen. camaro's? Is it worth going to the longer ones or not? Also who would be name brand of choice? Thanks Eric
Z28-69 is offline   Reply With Quote
Old 06-24-2009, 01:38 PM   #2
sixty8
sixty8's Avatar
Default Re: Ball Joint's of choice?
I went with a Howe upper ball joint and am happy with them. Here are the numbers for stock a-arms in the first gen Camaro. I ordered them separate and assembled them myself.
Howe upper joint pn - 22303
.5 longer stud - 22385
sixty8 is offline   Reply With Quote
Old 06-24-2009, 08:23 PM   #3
Z28-69
Thanks....I will check those out. I know this has been discussion before, however I wasn't paying attention at the time. Does the .5 inch help get more travel? Is that the reason guys use them or is there another reason?
Old 06-25-2009, 12:45 AM   #4
sixty8
sixty8's Avatar
You will get more travel and in my case more than my QA1 shocks could extend. I had to use an adjustable bolt setup on the upper arm to keep the shock from hitting it's limit. I have between 5.75 to 6 inches of travel measured at the fender lip and the car sits almost touching the lower bumpstops. I believe that it will also help reduce bumpsteer. I bracket race my car and these ball joints might be illegal for stock.
Old 06-25-2009, 04:53 AM   #5
blasttime
blasttime's Avatar
Why would you not use the correct required length for your applacation? This is not a well thought out modifcation in my opinion.
blasttime is offline   Reply With Quote
Old 06-26-2009, 09:13 PM   #6
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: Ball Joint's of choice?
You can maintain the camber better at full lift with the longer ball joints.
I like 'em!
Jim Cimarolli is offline   Reply With Quote
Old 06-26-2009, 09:21 PM   #7
Jim Cimarolli
I like 'em!
Old 06-27-2009, 12:16 PM   #8
Z28-69
Thanks guys for the input. Helping my brother select parts for his 68 that we are putting together. Helps to buy the right parts the first time. Not later on! Eric
Old 06-27-2009, 12:26 PM   #9
Liked 1,925 Times in 432 Posts
Actually, it is a very well thought out modification. Without the longer ball joints, you have serious alignment and bump steer issues, and you are over stressing the ball joints by using them for stops, and doing it at a severe angle. The car will work much better with the longer ball joints.
Old 06-27-2009, 02:11 PM   #10
blasttime
blasttime's Avatar
Wink Re: Ball Joint's of choice?
Measure your shock compressed and extended buy the right length ball joint. Why would you install .5 long stud to ruin a shock .1,.2,.3,.4,.5 length studs can be had.
