#71 |
Liked 4 Times in 4 Posts
#72 |
Even if they won't allow the Indy's why can't we run the Edelbrock head? Should would make it alot cheaper than trying to find originals or repops that weren't wortha s**t! To try to run with the new injected cars is insane. If you ask NHRA to take OFF some horsepower all they do is say no thanks. You just can't get a flat hooded 63 dodge to run like the scoop hooded cars. NHRA just won't listen or doen't care.
Bill Brennan 1062 STK |
#73 |
The high comp. 64's will get to "C", not sure about the 63's. Even then, you can't find a good set of heads, and finding the aluminum front end is impossible. NHRA should let them run the Edelbrock max wedge head as was suggested, and let them use the fiberglass front end (IHRA already does, I have a copy of an e-mail somewhere, and Harley Day's beautiful 64 Plymouth has a glass front end). There used to be a ton of 426 max wedge cars in super stock, where are they now? - Mike Cissell had one running about 4 years ago.
#74 | |
I live in FL and no one has seen Mike around for a while, if anyone knows how to contact him, let me know. Jim |
#75 |
Guest
Posts: n/a
David, a few years ago I bought some A990 parts from Ralph Ronzello and he said hea had a 64 plymouth with Nascar set-up. You might check with him.
#76 | |
Banned
Liked 235 Times in 110 Posts
#77 |
Liked 16 Times in 11 Posts
Terry, The problem is Mopar sells a replacement head, nhra has it listed but it is junk, alot of machine work is needed to even use the head. On the other hand if Edelbrock has made changes you would have to send a head to Mike. We did it with a piston for a crate motor racer a couple of years ago. nhra could care less, they do not even answer emails anymore, I have emailed 3 times about a pan listed on the Stock pan list that Moroso dose not even list any more and the other pan is listed short 2 qts. They just dont care.
Bob Pagano A/SA |
#78 | |
Banned
#79 | |
Terry, when has the NHRA ever given a darn about Mopar guys, they have always left me with the impression that they wished we would just go away. Jim |
#80 |
Liked 11,029 Times in 2,266 Posts
Just like I thought, John was the winner in AA/SA at Norwalk
