Old 06-29-2009, 09:38 AM   #1
JeffM
Liked 5 Times in 5 Posts
Default SBC leaks
I have a couple of minor leaks in 2 spring pockets and wondered if anyone can recommend something to pour in the waterjackets that will help seal it. New heads are not an option right now, but is there anything that can work?
thank you
Jeff
JeffM is offline   Reply With Quote
Old 06-29-2009, 01:14 PM   #2
Michael Pliska
Default Re: SBC leaks
thank you
Jeff
Jeff,
I have successfully used K&W block seal on Chevy 6.2L diesels with head cracks.
Regards,
Michael Pliska 643 S/G
Michael Pliska is offline   Reply With Quote
Old 06-29-2009, 03:26 PM   #3
BlueOval Ralph
Banned
A company in louisville, ky used to make a product called Versnick outstanding for cast iron just don't get it on any window glass. Not sure if is still around.
Originally Posted by Michael Pliska View Post
Jeff,
Regards,
BlueOval Ralph is offline   Reply With Quote
Old 06-29-2009, 03:42 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
I used to use Sherwin Williams Tilex 2 part floor epoxy, it flows into the water jackets very well,and held up well...........Tom
Tom Goldman is online now   Reply With Quote
Old 06-29-2009, 07:49 PM   #5
Joe DeMarzo
Liked 121 Times in 11 Posts
I have used liquied glass many a time and it works well and lasted the last half of a season (50plus runs).
Joe DeMarzo 1317 STK
Old 06-30-2009, 09:59 AM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,984 Times in 597 Posts
Jeff,
Go down to the local craft store and get Envirotex. It is the 2 part epoxy they use to pour bar tops. I just fixed my heads that had the same problem. I welded the crack in the spring pocket. Then I cleaned the water jacket using Castrol Purple cleaner. Let that dry real good. I force dried the head with a small heater. Then turn the head over and pour the epoxy into the water jacket. I had to put some tape over the water inlet on the manifold side to keep the epoxy from running out. When you get the head in the right position you should see the epoxy starting to come out where the crack is located. I let the epoxy cure for a week before starting the engine. No water in the oil at all.
Mike Pearson 2485 SS
Old 06-30-2009, 10:34 AM   #7
JeffM
Thanks fellas. I was also recommended this stuff from Casewell that sounds similar to what you are describing. Just hope to get it sealed up enough to last me 75 runs or so.
thanks again!
Old 06-30-2009, 11:05 AM   #8
Jack McCarthy
Liked 511 Times in 122 Posts
Lightbulb Re: SBC leaks
bowling ball plug will work, check with local centers who have a pro shop
jack mccarthy
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
