Old 07-01-2009, 07:53 AM   #1
496StrokerOlds
Default Oldsmobile aluminum head package+misc parts
I thought I would offer this as a package deal for someone looking to build something decent...all parts are used with very very little run time on them....changing combo, but things need to go first:
Package:
~Rocket Racing Heads that have been completely ported with a race prep valve job, new valves, and spring pocket area has been machined to accept common chevy valve springs.
~1/2" head studs
~ Manley Nextek valve springs with titanium retainers
~Harland Sharp 1.7 ratio rockers with studs and poly locks
~ Trick flow hardened pushrods 3/8"...9.850" length
~ Comp cams solid roller lifters with tie bar
~ Bullet custom solid roller cam
Duration @ .050 I 272 E 279
Lift @ .050 I 765 E 740
111 LSA installed at 107
~Rocket Racing intake with spacers....intake has been ported to match heads
Looking for 3500.00 for all mentioned above.
Misc parts:
~Rocket racing valve covers with hole machined out in each for breather or evac setup. 150.00
~BHJ Balancer-internal balance 300.00
~ ATI Flexplate-internal balance 160.00
~Flow kooler waterpump with outlets tapped and blocked off 60.00
~ Moroso 8-quart oil pan. a few scrapes on bottom and a few small dings...nothing to hinder working ability 150.00
~ Mellings blue printed oil pump that has been shimmed and moroso oil pickup for above pan 80.00
~ Kooks headers for A-body...one tube on passenger side was modified to fit chassis due to motor being set back. Painted high temp black. 2" primaries with 3.5" collector 400.00
~ Billet timing pointer 30.00
~ BRC Custom pistons that were mathced with 6.800" rods and an offset ground 425 crank (4.250 stroke) yielding 13.4:1 compression. Make offer...cost 700+new to have them made. I can get all details on them if anyone would be interested.
If there are any questions email or PM me...if there is anything mentioned that might be wanted I can work on prices and combine things for shipping purposes. Trying right now for a package deal as everything was matched together so it would be nice to sell like that first.
Thanks!
496StrokerOlds is offline   Reply With Quote
Old 07-09-2009, 06:31 PM   #2
racer1442
racer1442's Avatar
Liked 2 Times in 1 Post
Default Re: Oldsmobile aluminum head package+misc parts
PM Sent
racer1442 is offline   Reply With Quote
Search this Thread:
Advanced Search
