Liked 51 Times in 14 Posts
Do those of you that run Hoosier Radial 9x30 rotate them every so often? How often? How many passes do you get out of them on average? Thanks,
Jeff Ross |
Liked 200 Times in 80 Posts
I rotate mine aout every 4-5 runs. They usually last about 90-100 passes,if you don't get crazy in the water and try to look like John Force.
Mike Fuller 396 STK 3961 SS |
Liked 6 Times in 4 Posts
Liked 55 Times in 29 Posts
I was talking to a hoosier tire rep the other day about which way the tires should be mounted, he said it did not matter. he also said you should only rotate them if the tread starts to feather up, and after a run or two you should put them back. do not switch them back and forth. they will last longer this way.
Liked 56 Times in 27 Posts
j gardiner,
I agree and have been doing it that way for 10-15 years...They do last longer, and you don't need to have a Smoke-Show anymore, just a little smoke is fine....LOL, * They still outlast the rest in Radials.........
Dave Ribeiro 1033 STK |
Same here.....I've blazed "em to the starting line and done a burnout with what you can barely call smoke. 60's arent any different.
65 runs, same side. The best part...I push it in the trailer at 20lbs, I back it out a month later. 20lbs in each tire! (even with a new found plug in one tire) |
#7 | |
Liked 759 Times in 379 Posts
![]() Afterwhich they go on a less power/lighter mid 10 second car for another 75+ passes. The most I ever put on a set was 115 passes at the end of the season on good starting lines. Last edited by 1320racer; 07-22-2009 at 08:33 AM. |
