Old 07-22-2009, 06:21 PM   #1
demps45
Question 396/375 Replacement cyl head
As an old racer thinking about getting my 69 chevelle back on the track - is the 401 alum cyl head acceptable on "all" 375 HP engines?
Fred Dempsey
G/S, H/S, I/S, D/SA
demps45 is offline   Reply With Quote
Old 07-22-2009, 08:45 PM   #2
Liked 1,874 Times in 422 Posts
Default Re: 396/375 Replacement cyl head
It's legal for the 69 396-375. Of course, you should check the guides for the factored HP, the weight, and the specs. All of it is online now at the NHRA site.
Old 07-23-2009, 10:28 AM   #3
demps45
Thanks Alan, I have checked all the NHRA specs, factored Hp and such, but was a little confused regarding the 401 alum head use on my Chevelle. At one point in the specs, it mentions the alum head for the Nova and Camaro only, but I have since learned it is also legal on my can. Thanks again for your help.
Fred Dempsey
G/S, H/S, I/S, D/SA
Old 07-23-2009, 01:47 PM   #4
mannymen
Liked 13 Times in 7 Posts
Question? Isn't the 401 replacement head an open chamber head at 118 + - CC's? The 396/375 combo is a closed chamber 106 or so CC head. Can someone explain whether one is allowed to modify the chamber or to decrease the CC's on the head to run stock or even SS? Can you run it as an open chamber and are you then allowed to use the open chamber piston that fits the combustion chamber better. Confused on how this works. I thought I saw an SS camaro racer running an alum head 427, but claim the 445hp instead of the 476hp for the L88 open chamber headed motor.
N/A
mannymen is offline   Reply With Quote
Old 07-23-2009, 02:29 PM   #5
demps45
Mannymen - According to the NHRA specs, the stock cast iron head is listed as 104+cc, and the 401 alum head is at 103+cc. Also, the alum head motor is factored at 405HP and the cast iron head motor is at 390.
Fred Dempsey
G/S, H/S, I/S, D/SA
Old 07-23-2009, 07:30 PM   #6
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
The LS-6 454 SS engine combination has used the open chamber heads at the closed chamber CC for years and years. I machined a number of sets so I know how they got from 119 cc's down to the legal CC number.....
I just had a friend ask me about doing an engine using the 401 heads and wondered the same thing...How did these heads become acceptable for an engine that used CC heads. I am assuming the arguement that the legal iron CC heads are getting harder to find and more expensive is how these aluminum heads came into the picture...... '840's and '291's There are also aluminum CC stock GM versions..... A friend has a set....
Rich Biebel
S/C 1479
Stock 147R
Old 07-23-2009, 09:51 PM   #7
mannymen
Ed and Rich,
So you guys are saying that they modify or aluminum fill the 118 CC open chamber 401 head to get it down to the 103 or 104 CC closed chamber spec in both Stock and in Superstock?
sorry for my ignorance
N/A
Old 07-26-2009, 07:45 PM   #8
Bryan Broaddus
Liked 18 Times in 4 Posts
I have run the 1971 425 HP LS6 with the 401 alloy heads for several years. You can angle mill the heads to get the chambers down to 104 cc's. Same thing on the Iron heads. You have to cut .100 off the plug side and 0 on the manifold side, then correct the intake manifold face.
Bryan Broaddus 7568 STK ,SS
Bryan Broaddus is offline   Reply With Quote
Old 07-27-2009, 05:23 AM   #9
Rich Biebel
I didn't want to be the first one to say how I made them the right CC's......I angle milled the iron open chamber "990 heads......zero to .125" than flat milled them the rest of the way. corrected the intake side and faced the head bolt bosses to make them for an LS-6....I did not realize the 401 heads were being used for that engine as well.....
Rich Biebel
S/C 1479
Stock 147R
Old 07-27-2009, 06:45 AM   #10
bsa633
Banned
when you angle mill a head you change the valve-angle..another of those "grey areas" i guess..while many makes doesn't get a replacement head at all..some others can just "make heads fit"...
bsa633 is offline   Reply With Quote
