Banned
Liked 64 Times in 22 Posts
Ive been fighting a problem with keeping pinion shims from coming apart & out.car is a 95 camaro stocker but I run it in SS with SS motor.weighs 3400lbs with p/g & 99% of the time it is foot braked.it has a Strange housing ,which I figured would be better for making things last longer,but after 50-60 runs,it will start making noise & when I check,the shim is gone.this has happened 3 times in the last 2 years.I use the ratech collar instead of crush sleeve and always get pinion depth within .003-.004 of what is written on gear.Pinion nut is still "tight" from the loctite but of course has some slack from the lack of shim.The nut backing off doesnt seem to be the trouble as I have marked it before to see if that was the case.any ideas,suggestions(dont want to change housings),something I am missing???got lucky this time and didnt hurt gears,not so in the past....let me know............thanks Vic Penrod
Liked 57 Times in 33 Posts
Vic what rear end cover are you using? Not sure if its the problem or not but you should use a cover like the one T/A sells. Moser does also (think T/A makes them for them). Ive heard stories about the 12 bolts where the main caps actually "flex" on the launch. Maybe its flexing causing things to beat around in the pinion?????just a guess, something worth looking at maybe.
Duane Eiskant 1354 Stock/Super Stock |
I don't know what's causing the problem, but why don't you put a shim under the bearing race, like on a Dana?
#4 | |
Liked 460 Times in 91 Posts
Thats what I do in my 12 Bolt
Bob Bender 144 O/SA 2010-2012 National Record Holder |
Liked 110 Times in 29 Posts
Sounds like not enough pre-load on the pinion. How much do have on inital set-up? I've always set mine 15-17 inch pounds. I see where Ratech now has a "Smart Sleeve" that you may want to try instead of the solid spacer. Good luck. Danny
Liked 1,892 Times in 423 Posts
Never had a good pinion shim fail, unless the pinion nut is backing off, or not tight enough to begin with. It is also possible that the bearings are not getting enough preload. Ordinarily, it will kill the shims on the spacer before it hurts the shim on the pinion bearing.
Alan Roehrich 212A G/S |
Liked 320 Times in 102 Posts
You're not honing the forward pinion bearing to make it easier to set up the pinion depth??
Are you??? Bob
Liked 535 Times in 110 Posts
Mark is correct. I had similar problems years ago with mine, shims getting damaged, but the Ratech severe duty pinion shim kit #1901 solved the problem. Kit relocates shims between the housing and the race.
Jim Kaekel 3836 STK |
Guess I have been lucky. I've never had that happen. I think you need to get closer with your pinion depth, but that won't effect the shim problem. I have broken teeth on one ring gear, and found them cracked on another a few weeks back, but my shims have always lived. That's a new one for me.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 08-03-2009 at 05:16 PM. Reason: Spelliing |
Guest
Posts: n/a
Thats what I'm thinking Bob, The pinion bearing still needs to be a press fit. If not the bearing will spin, even with a Ratec solid collar. Alot of racers hone the bearing so they can change gears or repair at the track.This may work at time but not all the time. I'd use a new bearing or if the pinion was sanded some loctite sleeve retainer on it. That should help your problem...
