Old 07-29-2009, 08:20 AM   #1
chevy620
Banned
Question Rocker Arms- LT-1
Started cracking some of these and wondered if there is a good brand that lives or have I just cycled these long enough I need to replace a whole set?
Valve springs and retainers for LT-1?
Can pushrods be the root of the problem?
My engine builder retired and looking for some help on the right parts. I know I can count on you guys, right?
Thanks,
Jok
chevy620 is offline   Reply With Quote
Old 07-29-2009, 01:29 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: Rocker Arms- LT-1
Crane Nitro-Carb...if you can find any......and there were supposed to be some decent ones available from Competition Products......but I am not sure on that. I had Bullet springs...dampners broke.I Installed a set of Competition Products electroplated units and they held up fine. Comp cams springs and retainers are also good. There might be some beehives that would work well......PAC I think is the name that sells those and they have a website.....I was looking into those.......
Rich Biebel
S/C 1479
Stock 147R
Old 07-29-2009, 06:46 PM   #3
Tom Turner
If you cant find any Crane Nitro Carb units, I am told that Elgin has comparable units and the guys at Competetion Products always have something good. I have used stock LT-1 units that have been nitrided and cryroed and never broke any.Kinda expensive to build though. I think the trick with the rockers is to get the lifter travel under control. If you stop the lifter from taking a .150 run at the rocker, the breakage seems to stop. The spec is .015, I run mine at .018 or so.
The best valve spring setup for LT-1 in my opinion, is the Comp Cams beehive setup. They have the springs (I use the stout ones) retainers, spring locators and locks that solve all problems that these heads seem to have. They last forever, even with harsh use and rpms in the 8000 area.
Jason Line told me to use as big a pushrod as I could get into the engine. I use Smith Bros 3/8 units because the 7/16 test unit I tried will not clear the port without offset lifters; not really legal in stock.
If you need more help, my email is KVIAUTOGUY@aol.com
Tom Turner is offline   Reply With Quote
Old 07-30-2009, 07:11 AM   #4
Ross Family Racing
Liked 51 Times in 14 Posts
Get ahold of Jim Bailey at Finished 330-858-1842. He has a process that greatly helps these parts. Call him. He told me that he does these for an engine builder on the west coast and does them by the gross. Must work!!
Jeff Ross
Ross Family Racing is offline   Reply With Quote
Old 07-30-2009, 04:26 PM   #5
Bub Whitaker
Jeff Ross
Yes by all means, Jim Bailey is the one...Helped one of my customers who was breakin rockers every pass. Ford 429 solid lifter with fulkrum and pivets, use to break at the bottom or send the pushrod thru...no more
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 08-03-2009, 06:49 PM   #6
chevy620
Banned
Thanks guys.
Got a good connection at Comp Cams, looks like I better call them for some springs, retainers and heavy wall pushrods.
I heard pushrods are sometimes a bigger culprit than the springs??
See ya at the stripe.
Jok
Old 08-03-2009, 08:30 PM   #7
Jesse Knapp
Call Tim Cole at Comp Cams. He is very knowledgable about this stuff. I had been running 3/8ths pushrods in my engine and wanted to go to larger ones without cutting heads more. He sent me a set of 7/16ths rods that are tapered to 3/8ths on each end. Worked great for me. They are expensive, tho. He really educated me on what happens to a pushrod with todays spring pressures.
Jesse Knapp 4899 STK, SS
Jesse Knapp is offline   Reply With Quote
