Old 08-12-2009, 05:59 PM   #21
Chuck1280
Default Re: Who Sells the Adjustable Brake Pressure Launch Control Switches??
Your not allowed to use the finger button anymore?
Chuck1280 is offline   Reply With Quote
Old 08-12-2009, 08:18 PM   #22
Darcy Clarke
Liked 511 Times in 35 Posts
Hi Bob,
If I make it there I will buy the first round!!
Darcy
Darcy Clarke is offline   Reply With Quote
Old 08-15-2009, 02:22 PM   #23
Bench Racer
Liked 99 Times in 21 Posts
While on the subject, you used to see a lot of brake line pressure gauges in use. Normally how much pressure is required to lock the front brakes during a burn out, or staging the car? I know you see a lot of guys pumping the brake pedal as hard and quick as a Nascar jackman lifting the car for a tire change. Don Jackson
Bench Racer is offline   Reply With Quote
