Old 08-13-2009, 11:52 AM   #1
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Default Best braking method to scrub off .005-.01
I have been breaking out by an average of .005-.006 this summer so many times now that I cringe every time I pull up to the slip shack. The dial in is an educated guess using past runs of course and handheld weather station.
I have been getting off the gas but its now time to get some advice on this. Its an auto 89-90 mph in the 1/8 110 in the 1/4, two step button on the brake petal.
At a lot of the tracks I race at tire smoke is a black flag.
Suggestions?
Thanks
Eric
Eric Merryfield 1883 STK
Old 08-13-2009, 12:01 PM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: Best braking method to scrub off .005-.01
Dial down one number. Sorry you left the door wide open. I've found that simply lifting on the accelerator loses basically nothing, as your momentum is already at max near the finish line. I've been of course not very sucessfully "rubbing" the brake with my left foot trying to close it up at the stripe.I watched the Moser Shootout at Martin Michigan and was amazed at the amount of excessive braking during the race, some cars had smoke some got a little out of shape. I'm not a big fan of "spiking" the brake at the finish line however I know it is common pracice among some racers. That's my take on it your results may vary. Joe
Joe Buchanan SS/BX 3117
Old 08-13-2009, 12:07 PM   #3
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Put a gallon of gas in the truck before you run. and/or knock off your high gear shift point by 100-200 rpm.
For braking, if you're doing the chasing, when you catch your opponent, stay flat in the gas, and tap-tap-tap on the brake to hold that relationship. If you're being chased, try to use your mirrors to determine who's going to get their first. If you can tell you're going to get there by a fair margin, but you're not sure by how much, you can scrub the brake lightly a little bit as described above to take up a little bit of the room early, and then make the determination later in the run on whether or not to kill some more.
Unrelated -- replace the brake pedal 2-step setup with a brake pressure switch for improved R/T consistency. (see Tech forum)
Old 08-13-2009, 02:20 PM   #4
THE LEGEND
Call Manny Sousa or Chris plott. I bet they know.
CHip
THE LEGEND is offline   Reply With Quote
Old 08-13-2009, 02:54 PM   #5
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Hell i say we go back to racing off the index...(if they do, im getting my old motor back that way i may have a shot lol)
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 08-14-2009, 08:13 AM   #6
Ed Wright
Ed Wright's Avatar
And no break outs, right?
Ed Wright 4156 SS/JA
