Liked 99 Times in 60 Posts
Gasoline proof epoxy
Racers, What brand/type epoxy is suitable for use in the carburetor air horn and booster area? Specifically to form a radius near those areas. Not that the material will be submerged in gas, but some contact from gas will happen in that area. Thanks
Larry Woodfin 471W |
Thanks for the private reply's, I have the needed info.
JB Weld would be my choice. Look at their website they say their product is good for fuel cans and fuel tanks so I think it will be OK for your application. Once that stuff cures it is as hard as the sidewalk. It also can be drilled or machined. Drawback is it takes 24 hours to cure properly.
To be on the safe side, try a trial area on the materials you are going to epoxy to make sure it is compatable.
Nelson Kowal Stock 345 |
Liked 330 Times in 178 Posts
Larry--I sent you a email/PM did you get it--Thanx Comp 387
FED 387
check your PM
Liked 370 Times in 101 Posts
permatex makes several epoxy kits for repairing gas tank leaks
http://www.permatex.com/products/Aut...ank_Repair.htm
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
Liked 110 Times in 29 Posts
I stopped using JB Weld when I seen how it softened up from pump gas. I now use a military grade epoxy from Smooth-On called MT-13. Without question it's the best I've seen. Check them out at smooth-on.com. Hope this helps. Danny
Banned
Smooth On has been around for years it is also great for Cylinder heads and Intake manifold repair
