Old 08-14-2009, 11:49 AM   #1
FED 387
Liked 333 Times in 180 Posts
Question 1966 389 pontiac oil filter
My grandson has a 66 GTO with the 389 engine AND HEADERS--- does any one know of a short or shorter than stock oil filter that will work so that we do not have to drop/remove the headers to change the oil filter every time ---thanx Comp 387
Old 08-14-2009, 01:45 PM   #2
Steve Williams
Default Re: 1966 389 pontiac oil filter
Dick,
Tell your grandson to put in a Chevrolet engine and that will cure the problem. Hope all is well.
Steve
Steve Williams is offline   Reply With Quote
Old 08-14-2009, 01:57 PM   #3
FED 387
Exclamation Re: 1966 389 pontiac oil filter
Steve ---this car is too nice to do that ---but a good idea tho---been recuperating from prostrate surgery now, kinda screwed up my summer--- hos your dad doing??? say hi for me--thanx Dick
Old 08-14-2009, 02:22 PM   #4
desbird
a caddy filter from a same year is shorther and same thead chuck
desbird is offline   Reply With Quote
Old 08-14-2009, 02:30 PM   #5
FED 387
Chuck --thank you!!!
Old 08-14-2009, 03:35 PM   #6
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Pontiac also had a filter adapter that rotates the filter back at a 45 deg angle . Available from some of the Pontiac restoration sites. Used on Gen 1 Ram Air Firebirds, and 428 HO in 67-69 B-bodies. Then you can run a full size filter.
Old 08-14-2009, 03:59 PM   #7
7820
7820's Avatar
Been there done that. First of all he will need the angled oil filter adapter if he does not have one. Then purchase a NAPA Gold 1522. This filter will be a little smaller in diameter and shorter.
BTW...the angled oil filter adapter will point the filter towards the engine.
7820 is offline   Reply With Quote
Old 08-14-2009, 04:33 PM   #8
AC, PF 61 is the small dia, full length filter. .....307 Olds
It's usually not the length that's the problem. It's the diameter, and getting it in and out of it's location.
Old 08-14-2009, 05:24 PM   #9
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: 1966 389 pontiac oil filter
FED 387,
Just what Mark & ss3011 said on the adapter... You can also use a walmart filter
#3675 small dia/ full length... There is a small dia/ skort length but I didn't have number..
Filters work great and also fit my 5.7 + 6.0 GM Suburban....
Dave Ribeiro 1033 STK
Old 08-14-2009, 05:51 PM   #10
FED 387
thnx to all that replied----- after digging thru thru the Napa parts bins we found that a 98-02 Camaro will do the job----again thanx to everybody---Comp 387
