I have to ask a very basic simple & maybe dumb question. How do you guys set initial timing with a new chevy bbc & new msd distributor insallation (starting from scratch)? I am only asking,because i know you guys are very very slick & know more tricks of the trade than i will ever know. kirk
Liked 306 Times in 103 Posts
If advance is locked whatever you set time on as example 36btdc rotate to that,you can plug spark plug hole with finger so you can feel compression. Take marker put line on dist just below cap that lines up w/center #1 on dist. cap,drop dist.in where you can line tip on rotor button w/mark on dist. if you have mechnical advance you'll do same way except after dist is in you'll pull rotor around against springs the way it would be if mechanical advance was advancing and rotate dist. housing to line up mark on housing and rotor button.snug dist. where can move when running to make final adjustment w/timing light.This will
get you close. Mike Taylor 3601 |
