Old 08-18-2009, 07:06 PM   #1
RCM426
Question Car falls down as it leaves line
Car leaves the line hard and falls down and picks up and runs after that any ideas to look at I have tried about all I can think of 60 ft time are about 2tenth off from last year any ideas thanks Rich
thanks for reading
Rich ST 3331
RCM426 is offline   Reply With Quote
Old 08-18-2009, 07:33 PM   #2
Cisco Kid
Cisco Kid's Avatar
Send a message via AIM to Cisco Kid
Default Re: Car falls down as it leaves line
torque converter! usually iif the 60ft times slow down the converter is usually going bad...i just went through the same thing..i sent mine to tci last tues and got it back today 250.00 to rebuild it..
Cisco Kid is offline   Reply With Quote
Old 08-18-2009, 07:36 PM   #3
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
thanks for reading
Rich ST 3331
Do you have any relays in your ignition system anywhere? Relay could be flickering on and off when the car leaves hard. Float level to high maybe and spilling into carb? Band ground somewhere. Lots of possibilities......
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 08-18-2009, 07:40 PM   #4
Gary Parker
Liked 425 Times in 56 Posts
I just had a fuel regulater do the same thing. Check the flow at the carb
Gary Parker 1617 STK
Gary Parker is offline   Reply With Quote
Old 08-18-2009, 07:57 PM   #5
7423
Holley carb?? Jet extensions..............
7423 is offline   Reply With Quote
Old 08-18-2009, 08:02 PM   #6
RCM426
Q JET I/SA car
thanks for all the replys
Rich ST 3331
Old 08-18-2009, 11:35 PM   #7
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Rich, you have a PM
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 08-19-2009, 05:57 AM   #8
DIAPERMAN
Liked 21 Times in 6 Posts
Talking Re: Car falls down as it leaves line
We had a problem with Larry's car check where your fuel line runs we had to put regulator in front of carb it solved problem
DIAPERMAN is offline   Reply With Quote
Old 08-19-2009, 09:48 AM   #9
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Question Re: Car falls down as it leaves line
Q JET I/SA car
Rich ST 3331
Secondary air valve opening to quick ??? Check the adjustment on the spring that controls the rate of opening.....Just a guess since it has a Q-Jet.
Old 08-19-2009, 06:03 PM   #10
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
maybe the car wats to be a .90 class car... leave, stop, go...
Tod Lane
Swartz & Lane 66 Nova
Swartz & Lane 79 H/CM Trans Am
Tod Lane is offline   Reply With Quote
