Liked 54 Times in 7 Posts
The recent post about broken Cal Tracs shock brackets had me thinking about different ways to tie down the car in the trailer.
On my 77 Camaro I typically loop an axle strap over the front subframe just behind the body mounts and use ratchet straps to tie down the front. On the rear I previously used the factory hole that the transport would have used in the rear frame rails but now the sub-frame connectors cover this hole up on each side. So more recently I have been looping an axle strap around the leaf spring just in front of the rear end on each side and then criss-crossing the rear straps to the floor. I would rather tie onto the frame in the rear but I do not see any really good tie down points. How are you other guys tying down your cars to minimize suspension movement in the trailer? Thanks, Chad |
Liked 13 Times in 7 Posts
I thought about welding U hooks to each side of the rear subframe and then just ratcheting them to the rear D rings. This would hopefully reduce the rear suspension from moving up and down. I already have a u hook on the front subframe to minimize movement of the front shocks.
N/A |
Liked 100 Times in 45 Posts
Besides using the cross straps front and back I put a block of wood under the engine cross member and use a HD 1" wide ratchet tie down over the energy absorb bumper tubes secured by e track on the trailer floor.In the back same thing with the tie down and two jack stands on the frame.The car doesn't move at all.
Former NHRA #1945 Former IHRA #1945 T/SA |
Liked 2 Times in 2 Posts
I use a pair of tiedown brackets from a Ford Taurus,and I bolted them to the subframe area on the rear of my car and also at the front bumper brackets.I use surplus military aircraft tiedowns with chain from the car to the trailer.The Ford brackets have an area that takes a chain hook,and they are real strong.
Nautilus Racing |
We wrap the tie down strap in between the inner ends of the lower control arm. In the rear we go around the rear axle outward of the center section. We also criss cross the rachet straps to equalize the load.
Nelson Kowal Stock 345 |
#6 | |
Liked 460 Times in 91 Posts
WOW !!!!!!!! ED it would take me a week to do that with my car .... ![]()
Bob Bender 144 O/SA 2010-2012 National Record Holder |
Not really Bob.Takes about 5 minutes more.Take a look out the mirrors at the car going down the highway.The shocks take a worse beating than on the track.I bet the car will tow better too.That's a Baluga whale you have back there.
i will be strapping mine down with straps around the front tyres & cross over the tie straps in the rear to stop the car moveing sideways in the trailer
now if i can find some of them inflatable chassis stabilizers cheap to slide under the rear i will be set regards rod |
#9 | |
Liked 101 Times in 52 Posts
You are correct, the car takes way more abuse in the trailer on our fine highway system than on the track. (Unless you brake a wheelie bar, then slam the front end down. Another advantage to having a slow car!) We used to do design work for the Army and they had some very exacting trailer standards, and one was crisscrossing the straps to prevent shifting of the load followed by securing the load vertically from bouncing. Then there was the angle of departure thing for the rear so you didn't get stuck on a hill... |
Liked 14 Times in 11 Posts
I had hook mounts (square 1/4" metal) welded to my front K-frame and use these to
tie the front of the car down in a X pattern. On the rear I use axle straps over each side of the housing also done in a X pattern. I have seen one open trailer that the guy has a Chevy Impala stocker and he has what looks like a large "I" beam mounted so when the car is loaded the front K member rides up on the "I" beam to take the movement load off the front suspension.
Phil Saran Parker, Colorado |
