Old 09-07-2009, 08:41 AM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face Olds rocker ?
Hey guys how or what do you drill the (i guess their steel) rocker arm fulcums with? My car has 3/8 studs & factory is 5/16....A regular bit just polishes it!!!!! HELP!!!!!
Old 09-07-2009, 08:43 AM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Olds rocker ?
probably hafta use Titanium nitride coated OR Carbide bit--run it at low speed in a drill press and flood the drill tip with coolant---water-oil --cutting flluid
Old 09-07-2009, 11:33 AM   #3
GLEN DEMENGE
xxxxxxxxxxx
Last edited by GLEN DEMENGE; 09-09-2009 at 08:48 AM. Reason: i put in the wrong phone numer
GLEN DEMENGE is offline   Reply With Quote
Old 09-07-2009, 04:06 PM   #4
greg fulk
greg fulk's Avatar
Red face Re: Olds rocker ?
I broke 1 @ Columbus Div race... I went & found an Alum. 1 from Judi Bureski's husband & we (dad & i ) drilled it out in the trailer... All the others I have are the steel ones & rockauto.com has them for $5.40 a pair so I got 3 pair just 2 be safe. I don't like having the steel ones on all cyl but one...mine is set up as adjustable with 3/8 studs & sb chevy push rods... I guess spinning one of these 307 6800 in the traps is a bit much?
Old 09-07-2009, 04:36 PM   #5
Alan Warman
Greg
I had to use a reamer to take mine out to 3/8.Just use lots of coolant when reaming them out.
Alan Warman
STK 4107
Alan Warman is offline   Reply With Quote
Old 09-07-2009, 04:49 PM   #6
Chris Hardy
Guest
Posts: n/a
Greg,
Set them up in a vertical mill and use a carbide end mill. The end mill is a bit expensive. But it will tear thru those rockers like they are butter.
Chris
Old 09-07-2009, 04:51 PM   #7
Greg Reimer 7376
Liked 719 Times in 220 Posts
Question Re: Olds rocker ?
Would an American Motors rocker arm bridge work here? I had one apart once( a 304 powered Jeep) and they looked real close. I don't remember the brand name part we used on the engine rebuild for the Jeep, or whether it was aluminum or hard steel.
Old 09-07-2009, 07:37 PM   #8
greg fulk
greg fulk's Avatar
Thumbs up Re: Olds rocker ?
Thanks Guys! Hope to have it flying for the Northern Sports Nationals!
Old 09-08-2009, 09:13 PM   #9
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Olds and AMC pivets will interchange. ......I use an end mill to take them out to .375"
[and LOTS of coolant]. ......Tom
Tom Goldman is online now   Reply With Quote
