Old 09-08-2009, 08:44 AM   #1
mopar68
mopar68's Avatar
Liked 44 Times in 27 Posts
Default Direct Connection Degree Wheel & CC Crankshaft Socket
Vintage Direct Connection degree wheel purchased in 1979; very good condition, i.e. not bent, etc.. I used it on six engines to degree camshaft: one 383, four 440's and one 426 HEMI. Also, Competition Cams crankshaft socket/degree wheel holder for Mopar engines. Like new, only used once. I sure wish I had it the other five times!
If you ever degreed a camshaft (duh!) on a Mopar, you know what a pain it is to turn over the engine via the crankshaft bolt in the counterclockwise direction because it wants to loosen--and it does, in turn, disturbing your degree wheel reading.
This special socket eliminates this problem by a) holding the degree wheel securely in place--WITHOUT over-tightening it--and b) you're able to turn engine over in either direction without the aforementioned nuisance because you're using the keyway in the crankshaft and not the threaded-in crankshaft harmonic balancer bolt to accomplish the task.
$65.00 (free shipping)
If interested send private message.
M68
Search this Thread:
Advanced Search
