Old 09-10-2009, 07:26 PM   #11
larry dowty
Liked 11 Times in 4 Posts
Default Re: Stock Valve Lift
thanks alan, we all know it is there game was just curious.
larry dowty 6388 SS
larry dowty is offline   Reply With Quote
Old 09-10-2009, 08:10 PM   #12
Tom Moock
Liked 10 Times in 6 Posts
BlueOvalRalph, Nhra has a devise they put your push rod and your lifter in to find correct length of your set up,then they put their lifter and your push rod in to get same length, they use a adjustable lifter, then they use this set up to check lift,. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 09-10-2009, 08:22 PM   #13
Rory McNeil
Originally Posted by Alan Roehrich View Post
Jeff, I asked this very question a week or two ago. I was told by a division tech director that NHRA supplies the solid lifter for checking lift on a hydraulic cam and you may not supply your own. I was working on a hydraulic lifter engine, and was going to just get an extra solid lifter and check everything, and give the guy the lifter to keep with him. I was told NHRA would not use any lifter I was going to provide, they would use their own.
I don`t how "oddball" a 5.0 Mustang Stocker is, but I`ve torn down 3 times here in Div.6, and the certification team never had a "solid" Ford hyd. roller lifter in their kit. The first time, I ended up having to disassemble on of my own lifters,& "plug" it. After that, I just kept a plugged lifter of my own in my tool box, and on 1 ocassion, the cert .team borrowed my checking lifter.
NHRA 6390 STK
M/S 85 Mustang
Old 09-10-2009, 08:46 PM   #14
Liked 1,892 Times in 423 Posts
I suppose I shouldn't be surprised that they don't have a lifter for that. They certainly should. Shoot, I have one that I use to check piston to valve clearance.
Old 09-10-2009, 10:18 PM   #15
Gary H Humrichouse
The check lifter they use it made by Clark Holroyd. He will sell one to you.
Gary H Humrichouse 736 STK
Gary H Humrichouse is offline   Reply With Quote
